It worked! Datamarine-Raymariine Depthsounder hook-up
126
C&C 29 MK-1 Mandeville (Lake Pontchartrain), LA
I successfully hooked up my old Datamarine transducer to a new Raymarine ST40 Depthsounder unit!
On my 1979 C&C 29, I had a 35 yr old Datamarine depthsounder transducer (thru-hull) and D/S unit installed. The transducer worked but not the unit, the LCD screen was blown. I did some research and saw where MaineSail and others said that they are compatible, so I bought a used Raymarine ST40 unit on eBay for $90 and installed it. You have to do some "finaggling" to connect the power cables (to the red & gray pins, not the yellow) and the transducer cables, but once all was set up, I flipped the power on and it whirred to life and is giving me accurate readings! Researched showed that both units and transducer are 200kz, so that's why they work.
Thanks MainSail for the info in the past!
Kev
