I'm just curious to know if anyone actually uses the shower on their 309?
I've never used mine (although I do shower elsewhere). I can see where having a shower available looks good at the boat show, but I'm a tad skeptical as to whether the shower on the 309 is really up to snuff for even occasional use.
On the plus side: There is a wrap around curtain and a pump in the floor. And the faucet extends to become a handheld shower. And the floor's fiberglass.
On the minus side: There's no fan to exhaust all that moisture. It's a little cramped (this will vary from body to body, of course). The shower curtain would be all wet when you're done...let it dry outside?
It's winter here in Muskegon, Michigan as I write this, so the boat's on the cradle and all snowy. Otherwise I'd just go take a look and see what I think.
If you've used your shower, did you find that the shower curtain actually did its job and kept the water away from places it shouldn't be?
Because I'm wanting to be able to do some nights on the anchor when traveling, I'd like to pursue this shower thing.
