Spring Project
81
Precision P28 Lake Ouachita
Now tahat I found out reading Peggy's post that a vented loop isn't necessary when pumping directly to a tank, I think I am going to re-plumb and take about 6 ' of hose out of the loop (no pun intended)
Dec 2, 1997
9,011
- - LIttle Rock
Whoa!! Maybe a good idea...maybe not.
No, you don't need a VENTED loop...but maybe a LOOP is a good idea?
Btw...in case you haven't noticed my location...I'd be glad to personally field test how well your system works. :dance:
Sep 27, 2008
6
Oday 27 Solomon's Island
The first list is for me to do, (and the hubby to assist with). The second will be with help from the marina. The last item, propshaft coupling screw seizing, I think I could do to, if I could see how it's done. The picture from my surveyor is here: any diagrams/pictures or guidance? All I see are hose clamps....
http://s869.photobucket.com/albums/ab259/odaysundance/?action=view&current=Propshatcoupling.jpg
TO DO:
Replace hose clamps on cockpit scupper hoses.
Straighten engine water intake hose (crimped - faith's doing during cold December winterizing..)
Double clamp below waterline hoses
Check fuel tank tiedowns
Replace Engine Exhaust Hose
Replace bilge pump. Save old as spare.
Install cleat in anchor locker
THESE ITEMS I NEED ASSISTANCE WITH:
-Port side chainplate - delaminated. (I may be able to glass and fix.)
-Compression post replacement and cabin sole delamination repair.
-Rigging. Tighten and replace starboard side into spreader detente.
-Coupling set screw on propeller shaft coupling needs seizing on screw.
Dougo
Nov 22, 2010
82
Hunter 23 Great Sacandaga Lake, NY
Refinish rudder / tiller
Replace electric panel
Continue trailer rebuild
Touchup bottom paint
Rewire mast light socket
Remove "goo" from old decals
Hopefully sail the beast!
Jan 29, 2010
5
Hunter Cutter perth amboy
I am considering refurbing the galley on my 37 foot cherubini... Looking for ideas...
Apr 27, 2010
970
Beneteau 352 Hull #276 Ontario
I'm building:
1.) A Non-Contact Bilge switch with microcontroller and LCD to display control pump times, levels, alarm, Number of cycles.
2.) A Remote control for my Autohelm 4000
Love gadgets:D:D
MrBee
Dec 30, 2008
425
Irwin 34 Citation Middle River, Md.
As noted in my post for info on "How To"
will be installing,
Shore power.
New DC panel and most wiring back to batteries.
Above includes a Charge controller.
Gonna have to figure out were the AC panel will be installed, never had shore power.
First will be bottom paint then splashdown in late April or May.
New Larger holding tank, I knew the 9 gal. one i installed 2 years ago was to small but didn't want to do major mods at the time to fit a larger tank and the waste was going overboard with the PO.
Redo of Water tank and all else up to Faucet.
Bug screen set up to drape over Bimini once we are at anchor,if needed.
New Toe rail , i think that's were some of the leaks are coming from.
My guess is i'll be lucky to get the shore power and DC wiring done.
Nov 26, 2008
1,970
Endeavour 42 Cruisin
SPRING? why wait? Been working all winter long.
Replace forward holding tank
Replace all forward head hoses
Replace 3 thru hulls valves & hoses (did the actual thru hull in the fall before it got cold)
Replace Edson steering cables
Rebuild some galley cabinetry
Spring will net a bottom touch up & some waxing
Aug 20, 2010
1,399
Oday 27 Oak Orchard
"And so it continues." I haven't let up since I started the complete restoration in September. The biggee will be the starboard deck recoreing once the nonskid is reimprinted with gelcoat on the port side. Major restoration, major triumphs, major screwups, major fun and YOT is starting to look real good.
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
Rebed dodger frame.
Name/Hailing Port change.
New batteries.
Wash and wax.
Not much to do this spring! Not like my last boat where every day there was a new project!
Spoke too soon.....
Add change out gasket on toilet
Montgomery 17, Venture of Newport, Mirror sailing dinghy, El Toro sailing dinghy Mound, MN -- Lake Minnetonka
2010/2011 BOAT PROJECTS​
I should have done some of these over the winter but 1) I was lazy and 2) Life got in the way.
LINES
Seize & whip fender whips
Whip misc lines
Replace runner doubler - two splices
Change 2nd reef line on mainsail
Reconfigure boom outhaul
Splice line for mast raising system
Move lashing rings on backstay bridle
Seize eye in topping lift
Rig second mainsheet tackle
Make soft shackles from Dyneema
CANVAS
Add shackle to head of storm sail
Add ring to clew of storm sail
Finish pop top cover
Re-stitch & repair headsail covers
Re-stitch & repair mainsail cover
Add fabric to increase size of mainsail cover
Make cockpit cushion covers
Make cockpit seat backrest
Install Tell tale window on staysail
Spur grommets in leach of mainsail
CABIN
Make cabin sole grate or solid floor
Replace nuts w/tee-nuts on several fittings
Cut off excessively long bolts
Replace/finish pop top struts
Repair switch connection on ammeter
Replace labels on switch panel
Add larger bilge pump?
Add backing plate under forward cleat
Add larger backing plates under forward taffrail u-bolts
Replace barometer, weather instruments
Add Battery forward under V berth
Install 1-2-Both Battery switch
WOOD
Carve new trailboards
Sand, epoxy, varnish sliding hatch
“ hatch boards
“ grab rails
“ cabin eyebrows
“ sliding hatch rails
Touch up taffrails, toe rails, bowsprit
Replace or refinish tiller
Replace or refinish solar panel frame
Replace or refinish cockpit grate
Add wedge to forward cockpit cup holder
Refinish board for weather instruments
MISCELLANEOUS
Eye-bolts on aft taffrail spindles for aux mainsheet?
Bi-pod mast support?
Finish caulking hull-deck joint
Gasket for cockpit locker hatch
Gasket for forward hatch
Configure pad eyes for baby stays
Replace Cunningham clam cleat w/open clam cleat
Replace Reef 2 cam cleat w/open clam cleat
Refinish rudder cheeks
Paint rudder w/anti-fouling?
Design better rudder lock down system
Replace ¼” forward cleat bolts w/5/16”
Check gooseneck rivets
Move reefing blocks on mast to boom?
Replace/fix trailer wiring connector
Rebuild Harken 150 cam cleats
Replace spreader boots
File bow chocks
Move electric bilge pump outlet
Paint keel lock down bolt area
Replace rubber block in keel well
Check keel cable
Get, install tiller pilot
Bottom Paint
Replace outboard fuel line
Paint non-skid areas of deck, cockpit
RECESS
Dec 20, 2003
1,509
Catalina 27 . St. Mary's Georgia
Catalina 22
Complete overhaul, I am currently sanding the bottom to the gelcoat and sealing then bottom painting. I have a trip in two weeks in it for a weekend so I need to get it done. Then I will start on the topsides.
Oday 25
Reseat deck and rigging hardware. I have a 5 day trip to Cape San Blas in April and then a 5 week trip to the keys in June so I need to get on it.
Two boats... one bank account.... not easy. I am usually wore slap out!!
Feb 1, 2011
21
Sabre 426 Liberty Landing Marina
we are finally going cruising so we got the EPIRB in, the solar panels up and are ready for the cruising spinnaker which is finally ready for pick up. We also had the lifelines re-done 2 weeks ago...we need a 2nd anchor and chain. Other than that it is just spring cleaning and re-organizing for space optimization since we are now carrying everything we own with us.
BobT
Sep 29, 2008
239
Gulfstar 37 North East River, Chesapeake Bay
In rough order of priority and likelyhood:
Reinstall engine; out for leaking gaskets and oil lines.
but first: Replace cutless bearing while engine is out
but first: Add drip less shaft seal while shaft is out
but first: Clean years of oil scunge from engine sump
replace lifelines (already ordered)
touch up bottom paint
Then maybe: Replace hoses to holding tank/rebuild head
At some point: New line for in-boom outhaul blocks
Really should: Patch threadbare mainsail cover.
RECESS
Dec 20, 2003
1,509
Everyday for the last week. Got the last bit sanded today and the fairing compound on. Will do three coats of Pettit Protect tomorrow. It is a slow go, But I will get there.
RECESS
Dec 20, 2003
1,509
Another day, another 10 hours of boat work. Finished the three coats of bottom sealing today. I had to come all the way over the original boot stripe. Some owner in this boats past got lazy and bottom painted all the way up over the boot strip, so I wanted to seal all that area too. I will return it to the original bottom paint area and boot stripe.
Notice the jack stands built into the trailer. I have club members asking to use my trailer to do some bottom work on their boats now. One of our club members put enough HDPE rubrail and the rubber insert in the back of my truck for two boats. He said it has been taking up space in his garage for too many years. Serious score.
May 9, 2011
1
Beneteau Oceanis 352 Kingston
not sure if understood your posting but did you say you replaced the ammeter on your Oceanis 352? If so I am faced with a similar problem. Inexplicably my ammeter started going "negative"/ less than 0 when I push the check voltage switch. This started right after cleaning the contacts on the disconnect switches. I have checked the wiriing, all are on the terminal posts correctly.
In your posting it appears you did not simply buy another Beneteau branded ammeter.
May I ask what brand you replaced it with?
My boat is approaching 15,000 nm, lots of nagging problems, some not cheap. Leaking port gaskets the latest. Still sailing with original 98 sails.
Thanks...
I
