Rapid method to prepare at home for deep ocean sailing
RichH
Feb 14, 2005
4,773
1. Buy a dumpster, paint it "Hatteras-White" inside and out, and live in it for
six months.
2. Run all the pipes and wires in your house exposed on the walls.
3. Repaint your entire house every month.
4. Renovate your bathroom. Build a wall across the middle of the bathtub and move the shower head to chest level. When you take showers, make sure you turn off the water while you soap down.
5. Put lube oil in your humidifier and set it on high.
6. Once a week, blow air up your chimney with a leaf blower and let the wind carry the soot onto your neighbor's house. Ignore his complaints.
7. Once a month, take all major appliances apart and reassemble them.
8. Raise the thresholds and lower the headers of your front and back doors so that you either trip or bang your head every time you pass through them.
9. Disassemble and inspect your lawnmower every week.
10. On Mondays, Wednesdays, and Fridays, turn your water heater temperature up to 200 degrees. On Tuesdays and Thursdays, turn the water heater off.
On Saturdays and Sundays tell your family they use too much water, so no bathing will be allowed.
11. Raise your bed to within 6 inches of the ceiling, so you can't turn over without getting out and then getting back in.
12. Sleep on the shelf in your closet. Replace the closet door with a curtain.
Have your spouse whip open the curtain about 3 hours after you go to sleep, shine a flashlight in your eyes, and say, "Sorry, wrong rack."
13. Make your family qualify to operate each appliance in your house - dishwasher operator, blender technician, TV/VCR programmer, etc. Re-qualify every 6 months.
14. Have your neighbor come over each day at 0500, blow a whistle so loud Helen Keller could hear it, and shout "Reveille, reveille, all hands heave out and trice up."
15. Have your mother-in-law write down everything she's going to do the following day, then have her make you stand in your back yard at 0600 while she reads it to you.
16. Have your neighbor collect all your mail for a month, read your magazines, and randomly lose every 5th item before delivering the rest.
17. Watch no TV except for movies played in the middle of the night. Have your family vote on which movie to watch, then show a different one -- the same one every night.
18. Make your family's menu a week ahead of time without consulting the pantry or refrigerator.
19. Post a menu on the kitchen door informing your family that they are having steak for dinner. When they finally get to the kitchen, tell them you are out of steak, but they can have dried ham or hot dogs. Repeat daily until they ignore the menu and just ask for hot dogs.
20. Bake a cake. Prop up one side of the pan so the cake bakes unevenly. Spread icing real thick to level it off.
21. Get up every night around midnight and have a peanut butter and jelly sandwich on stale bread.
22. Set your alarm clock to go off at random during the night. At the alarm, jump up and dress as fast as you can, Run out into the backyard and uncoil the garden hose.
23. Every week or so, throw your cat or dog into the pool and shout "Man overboard, port side!" Rate your family members on how fast they respond.
24. Build a fire in a trash can in your garage. Loudly announce to your family, "This is a drill, this is a drill! Fire in storage locker #2 !"
25. Place a podium at the end of your driveway. Have your family stand in front of the podium for 4-hour intervals. Best done when the weather is worst. January is a good time.
26. Next time there's a bad thunderstorm in your area, find the biggest horse you can, put a two-inch mattress on his back, strap yourself to it. Then, turn him loose in a barn filled with snakes for six hours and try to sleep. Then get up and go to work.
27. For former engineers: bring your lawn mower into the living room, and run it all day long.
28. Make coffee using eighteen scoops of budget priced coffee grounds per pot, and let the pot simmer for 5 hours before drinking.
29. Have someone under the age of ten give you a haircut with sheep shears.
30. Take hourly readings on your electric and water meters.
31. Add 1/3 cup of Diesel fuel to the laundry.
Nov 8, 2007
1,618
Ahhh...the Navy!
You stirred a lot of memories of a time far away, and long ago.
olsalt
Nov 20, 2009
42
Oday 222 Oneida Lake in Upstate NY
Jump into your full foul weather gear, run outside in January, and have the local Fire Department hose you down while balancing on a Bongo Board.
Jun 16, 2010
98
Lancer 25 Newbergh
Just at the moment compared to the 3 deg. It is outside and dealing with the Ice that has formed in the gutters of the roof that is causing water to back up and run into the house
The 7 ½ feet of snow that I have moved with plow, snow rake, and shovel the almost 3 tons of sodium that I have spread so far this winter and the amount of winter remaining.
It sounds wonderful.
Tim R.
May 27, 2004
3,626
Don't forget to tear up 5 $100 bills while completing each activity above!
Jun 6, 2006
6,990
I'm with Billbeard
sounds great compaired to the current state.
Jan 10, 2009
590
PDQ 32 Deale, MD
For multihull sailors there are some differences:
  • Instead of a dumpster painted white, move into a pair of 30" diameter coregated pipes; one for you one for your spouse (this can be OK....). Agree to meeting times for meals.
  • Remove the springs from your car. Go off-road.
  • Leave the lawnmower running outside your bedroom door at night.
  • Disassymble and inspect the mower... in the space between the couch and the wall.
Feb 1, 2011
21
Sabre 426 Liberty Landing Marina
I've got some...lay a refrigerator box sideways (representing the lazerette). Put your lawnmower on one side and your hot water heater on the other. Get in between the two with your tool bag and take apart and re-assemble both items without dropping parts. Now take the same box and put it upright (representing the head), put your toilet assembly inside and get in with your tool bag. Take apart and re-assemble the toilet without getting the box bottom wet and nasty or taking a breath of fresh air.
Dec 25, 2008
1,580
catalina 310 Elk River
Mr. Wizard, I don't want to be a sailor any more!!
Drizzle Drazzle Drizzle Drone, time for this one to come home.
Blaise
Hunter 37-cutter Bradenton
Don't forget to have two big guys bang on the sides of the dumpster with sledge hammers.
RichH
Feb 14, 2005
4,773
Im not the 'author' of this work, I merely 'adapted the original' to be consistent with 'sailboaters'. The original has been circulating around for aeons and was in reference to US NAVY personnel.
LuzSD
Feb 21, 2009
1,009
Catalina 30 San Diego/ Dana Point, Ca.
What a great way to work my abs this morning, thanks all! And RichH, about half way down I realized this must be in reference to Navy experiences. This is so great, I am going to copy and entertain all my sailing friends (wait, I have lost all of my non sailing friends by boring them to death with sail talk!) this morning! Thanks and keep it up!
zeehag
Mar 26, 2009
3,198
that was truly funny and much is true f or sailing-- even tho it seemed navy-esque.... funnnny...
JVB
Jan 26, 2006
270
Schock Wavelength 24 Lake Murray, SC
Since "sodium reacts violently with water and with oxygen" your neighbors must be quite intimidated by now. Got video ?
http://science.jrank.org/pages/6221/Sodium-Chemical-properties.html
KMm
Aug 20, 2010
72
I have read the list and it made me think about all the things that have gone wrong on all the sailing trips I have taken in 40+ years. Then I thought about my first trip, getting out of my rack the first morning we anchored out at Channel Islands, Santa Barbara Ca. Watching the sun come up over the mainland and the sea lions playing in the water, I forgot every thing on the list. Lets face it there isn't one of us that would have it any other way, you can't go where we go and see what we see without paying a price. But God is it worth it.
Jun 3, 2004
298
'79 Hunter 33' HUN33190M79L Olympia
The main thing wrong with the list (like that one it came from) is it includes all the downside of cruising and none of the upside. If you really want to prepare you have to include things like:
-Fall asleep secure in the knowledge that when you wake up, you'll be in a completely different place from where you went to sleep (if you want).
-When you wake you'll be somewhere you've never been (if you want). Get ready for a new adventure every day.
-Breathe deep the clean, rich salt smell of a vast body of water that never gets old.
-Feel the earth move you, carry you, blow you. You are part of it. You can see it, smell it, taste it and feel it in every part of your being.
-The earth can feed you, for free.
-Get ready to be surprised by wildlife. Endlessly.
-Be the master of your fate. The ocean is huge, powerful and relentless; but if you know enough you can become a part of it, use it to propel you, and not be defeated by it. The feeling of this accomplishment is indescribable.
-Your boat and what it can do is an amazing testament to the genius of mankind. When you maintain it or enhance it, you are a part of that genius.
-The feeling of sailing, directing your sail through lift or push is like grabbing some invisible flier and riding it. Indescribable, and another rush.
Surely there is plenty more of the upside. What have I left out? And the problem is, you can't prepare for the upside by sitting in a can and pouring nails on your head or anything. That's why it's the upside.
