I have a 1989 Hunter Legend 37. The holding tank is leaking at the vent fitting on the top of the tank. It is not leaking where the hose fastens to the black barb, it is leaking from under the large thin washer. It is in a very hard place to get any access to do work so I want to be sure of what I do before proceeding. If I move the hose from side to side a bit, the large thin washer lifts off the tank surface. Seems like I should tighten the white plastic fitting, the one that the hose barb screws into, and the one that has the two tabs sticking out of. Is this correct? Should I try to take the fitting apart by unscrewing the fitting with the tabs? I assume there is some sort of mating fitting on the inside of the tank and if I don't retain this somehow, it would drop into the tank. I have not tested for what kind of material the tank is made of but since the fittings appear to be screwed on, I assume it is made of polyethylene or polypropylene. Is there some kind of sealant or adhesive that I could use if I take the fitting apart. Any help will be much appreciated.
