I decided that I'd better take a look at my lower tangs as well since I'm going to all this trouble and expense to start out next summer with a zero time rig that I won't need to worry about. So, this morning I went down and took off the lower tangs:
They have the same ugly score lines as the upper tangs I'm replacing so, in for a penny, in for a pound, this is the time to have new ones made, going to single thicknesses and using toggle forks.
Preparatory to laying out my new tangs, I drew up the old ones to see just how bad the lead angles were. Wow!
Think of the bending cycles these have been going through since 1980. I doubt that the pre-tensioning of the rigging is sufficient to pull them fully straight but sailing hard probably does. Then, when the rigging goes slack on the other tack, they spring back in. All this work was being done by the wire nipping at the end of the swage eye sleeves. Despite all this abuse, I can't see any sign of cracking or other problems either in the tangs or at the swage ends. It's been disturbing to find out how common this kind of rigging detailing is and it's a testament to the materials that you don't hear more calls to SeaTow to assist dismasted boats.
