jetski engine in a sailboat?
WayneH
Tartan 37 287 Pensacola, FL
OK, for extra credit, What happens to the DC motor when you stop using it to push your sailboat but leave it hooked up to the spinning prop while you're sailing?
Does the motor turn into a generator and partially recharge the batteries or not?
How much does the gen/motor slow you down while charging the batteries under sail?
Do you really need to install a separate generator if you're making a sufficiently long sail to top off the juice you used getting out?
Are is it all too inefficient to make a difference?
I have questions but not answers.
Johnb
Hunter 37-cutter Richmond CA
In the second of Ed's articles listed above the author comes close to but does not actually say,
1 The thrust you get from a propeller is proportional to the velocity of the wash
2 The energy put in (fuel consumption) is proportional to the square of the wash velocity.
3 Therefore the biggest, slowest turning prop possible for a given installation will be the most efficient
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
I'll play.
In a nutshell, yes the prop spinning the motor during sailing could theoretically be a charge source. I believe however that the current arrangement - shape of prop, friction of stuffing box, electric motor design - all conspire to make this fairly inefficient. But for the long-range cruiser, I guess this could still be a benefit. Improved, lower-friction drivelines will increase efficiency.This is something we very much need some real-world experience with.
Most cruisers want to have the availability of continuous propulsion, and many cruisers have high "comfort" electrical loads - air conditioning, refrigeration, etc, so a generator would almost always be present. Of course some sailors will manage their sailing and limit their consumption, so that they could possibly get by without needing a big generator. Just because one's present (for safety, backup) doesn't mean it has to be running often.
CarlN
Jan 4, 2009
603
Ketch 55 Bristol, RI
I spoke with Nigel Calder a year ago about his efforts with his hybrid test boat. He was quite excited about the potential for generating power from a spinning propeller but hadn't yet pulled it off. It still seemed quite daunting. His motive battery pack is 144 volts (how do you like that in a wet bilge) and even then the amperage was pretty amazing. A 30hp engine's power theoretically equal about 22 kilowatts - so you're talking a lot of electricity.
He also mentioned that most folding props wouldn't work since they wouldn't stay open when spun like this.
Theoretically, once you reach hull speed you're throwing away any extra wind power so using it to generate electricity would be a good idea. Below hull speed, I think most sailors want all the speed they can get and wouldn't want to slow down to generate electricity.
If you just want to handle "hotel" loads while sailing, water generators are a great idea. Hamilton Ferris has offered one for years and years that will generate about 15 amps (12v). This won't drive the boat but it will keep the beer cold.
http://www.hamiltonferris.com/water-power.html
Carl
Smithy
Dec 13, 2010
162
Macgregor 22 Alexandria, VA
To answer a question posed earlier, a jet system vs. a prop, on the same motor, will produce about 70% of the power of the prop. Average rule - I'm sure there are tons of variables to argue, but that was the rule of thumb when I worked at a marine shop in another life.
For a gunkholer, though, it makes a lot of sense as long as you can avoid grass and other crud that might stuff the impeller housing. And don't mind the efficiency drop.
Jan 4, 2010
1,037
Farr 30 San Francisco
Well the electric hybrid thing doesn't need a transmission. Modern electronics will allow you to run the motor in either direction.
The idea is seductive, an electric motor has quiet operation and is super reliable and doesn't stink like a diesel. So for just getting out of the harbor say 1/2 hr at 20kw you need 10kwh about 1000 aHr or so referred to a 12V system. That is a big battery. Now if you try to require 1000 Ahr to be no more than 50% discharge, battery requirement now becomes 2000Ahr. This is where the idea has problems. You can switch to more exotic chemistry than lead acid and reduce the size/weight of your 1000Ahr capable pack, but that drives cost.
If you want greater range than just getting out of the harbor, then you need a genset of some kind and about the same size as original diesel you replaced assuming high efficiency on the electronics side. The genset would probably cycle on and off to hold the battery between 50 and 80% of charge. in this mode it would be well loaded and you would avoid a long taper charge period of low efficiency, both as far as the diesel is concerned and as far as the battery is concerned.
Jun 6, 2006
6,990
Other reasons hybrid will not fly (sail)
A prop that delivers thrust will not be very efficient at producing torque from the water stream (aka produce usable power). So you are going to need an adjustable prop that can either figure which mode it is in for itself or have a user selectable switch/lever/button. My suspicion is that will be expensive in the extreme.
The long range cruiser could certainly benefit from this right up to the time he drops anchor. Then you have to fall back on solar, wind, or a genset. Since you spend 75%+ time at anchor this is not really a great solution.
If you concede that battery tech is not going to cut it for the foreseeable future then you are forced to embrace a genset driving an electric motor. So what is the advantage? Pumping it into the batteries for use later is a 20% reduction in efficiency. You might as well just stick with a gas driven prop. Your genset would have to be at least as powerful as your electric motor. Presumably you will want to have the capability to achieve hull speed. If that is true then you would need a genset that was approx 10% larger to account for the gas motor to electric motor efficiency. Does not make sense to me.
Assuming a miracle happens and batteries somehow get smaller, lighter, with more AH….. a miracle, You would find yourself with a high voltage electric motor on a sail boat. To get the required HP you would need wires as thick as your arm using 12 volts. It only becomes feasible when you get above 150-200 volts. Higher is better and some are quoting 460 volts used in motors available off the shelf. Not sure I’d be manufacturing these just because of the law suits that would ensue when people start electrocuting themselves. A galvanic reaction at these voltages would be dynamic to say the least. Stray currents in the water killing folks swimming near the boat (hay that could be me!!). A whole host of issues to failsafe. No doubt this would be expensive to engineer if even possible.
I personally think your money would be better spent enhancing your sail inventory and improving your close quarters sail handling skills/equipment. This would only add to your pleasure and make you a better SAILOR.
kenn
Apr 18, 2009
1,271
Hi Bill,
I know I won't convert you (or your boat), but I wanted to try to clear up some misconceptions.
We agree that the ideal driving prop won't necessarily be the best charging shape. But ANY prop is going to turn to some extent when the boat's in motion. No fussy prop required. So a more realistic expectation is - will a nice daysail that inefficiently spins the prop still regenerate the electrical energy required to motor out from and back to your dock or mooring? And in many cases the technical answer is already yes.
I'm only trying to make the case for hybrid systems, which would always include a generator. So in my scenario, the required battery capacity would be for only 30 to 60 min of motoring, with the expectation that generator-running is necessary to support extended motoring at hull speed. There will be conversion loss, but there's some efficiency recovered in that the generator IC engine is optimised for running at generating speed and load.
You're only looking at one part of the efficiency game. Yes, for propulsion only, the direct drive IC engine has an edge on efficiency... particularly if you're running it at it's most efficient point (eg 80% of hull speed). At different RPM the efficiency goes down.
Now let's say you need to run the engine at anchor to top up the batteries, or to run the AC or a fridge, (or a hair dryer). With a large engine turning a small alternator, you're now not very efficient at all.
The whole efficiency equation should also include energy cost, and system maintenance, and if the batteries are topped up between sails by shorepower, or solar or wind generation, then the typical boat user may not have to run the IC generator at all to support daysailing and race nights.
Another overlooked advantage of electric drive - it's far easier to quickly blip an electric motor for short powerful blasts in forward or reverse, compared to wrestling gearshift and throttle, and overcoming the higher inertia of a spinning engine. Docking should become alot easier. Notice I said should...
I suspect you're overestimating the electrical power required. Typical rule of thumb is to estimate 2.5 kW per ton of boat to do hull speed, and only 500w/ton for cruising at 70% of hull speed. For sailboat use, the systems seem to be designed around 144v DC max, with 48 and 72 v DC systems being more common. So from a voltage perspective, it's no more lethal or tricky to manage than shorepower, with currents averaging well under 100A.
Magic batteries aren't required. Hybrid power for boats is feasible now, and will only get more attractive as the advancements in auto EV batteries trickle down.
(further apologies to the jetski engine aficionados for usurping the thread. But you already know why jetski motors won't be appearing on sailboats anytime soon ;) )
10,254
If ya want to feel what it would be like to operate this way, try running your main propulsion engine (34+ foot boat) on a day tank with a 1-1.5 gal capacity. oh.. and restrict your ability to fill the day tank so that it takes 4-8 hours to get the diesel back in.. Not my cup of tea, but for those willing to put up with something like that and compromise the resale value and market size of the boat for re-sale, it might be good..??
6,990
Mixing apples and oranges
Hey Kenn
As a hydrodynamic engineer, all I can say is you don't understand the magnitude of the problem getting a thrust prop to produce torque.
I suspect that none of us are going to buy a 5000 HP diesel and idle it to go hull speed so your argument of "if you run it at the most efficient point" is pretty moot. Most boats are optimized for this already. However, your haunkin big genset, big enough to drive the electric motor to hull speed is going to be operating WAY below capacity when it is trying to charge batteries on a normal boat. Invest in electric hot water and oven cause you will have the capacity just sitting there going to waist. I don’t see the difference between that and a small alternator on a big diesel.
0.5 kW/ton@80% hull speed, lets see, 20 tons of boat would imply 10 kW. If you use 72 volts that is 10k/72=138 amps CONTIONOUS. I think if you look at the amp ratings on wires you will find that is one of the multiple otts sizes. Do you really think you are going to build an electric motor using that size wire? The IR losses alone are going to kill this idea. Unless you have some special motor wound for that application (can you say BIG, HEAVY and $$$$$$?) you are going to have to settle for an off the shelf model and those use high voltage. The guys at the hybrid shop are very leery of telling you the HP rating of their motors and for good reason. These things are 5 HP max. That is why they can get away with 72 volts. Even then they are pushing the limit of what is sane.
With all due respect Kenn, this is a great nitch idea but it is never going to take off mainstream.
kenn
Apr 18, 2009
1,271
Hi Bill,
First, errors in my arguments are most likely mine, and not the industry. (trying to argue a case is how I learn. Messy isn't it?)
So I am probably out to lunch on not a few points, most notably the required generator size, and failing to consider all the specifics of your size of yacht.
But you still seem to be running to extremes - conductors the size of your arm, big honkin' gen... How big is your current generator?... And there are a number of DC electric motors that do work in the 10s of kW range... somebody seems to have figured all this out.
... your haunkin big genset, big enough to drive the electric motor to hull speed is going to be operating WAY below capacity when it is trying to charge batteries on a normal boat
That would depend on the charge rate of your batteries, and faster-charging batteries are starting to come out of EV research. I still suspect a big DC asynchronous generator (not an AC genny with anemic DC charge output) is going to be a more efficient battery charger than an unloaded propulsion diesel driving an alternator.
On the HP front, somewhere I've read that given the different torque/RPM curves of electric and diesel engines, the most meaningful comparison based on hp is that 1 hp of an electric motor's rating is roughly equivalent to 3.5 hp rating of a diesel engine, which is of course why it's not so useful as a simple comparison.
(Any way of convincing you to switch sides, and help us look for ways to make this idea more feasible? ;) )
CarlN
Jan 4, 2009
603
Ken,
The other "wildcard" is reliability. The thing you "save" in a hybrid with diesel genset to electric motor is the transmission. In 40 years of sailing, the transmission is about the only thing that I've never had to fix. It can even take an occasional slosh from bilge salt water.
On the other hand, the electric system (chargers, regulators, batteries, wire connections, switches, breakers, fuses, gauges) are probably the most troublesome items aboard and seem able to corrode if salt water is within a mile's radius.
Carl
Jan 18, 2011
4
nytec nytec 27 Argentario (Italy)
In my opinion always use a diesel engine on a sailboat for tow simple reasons:
1) they last longer than gasoline engines.
2) the diesel vapor is not as dangerous as gasoline vapor in therm of flammability.
Johnb
In fairly round nunmbers, a pound of diesel, burned at 30% efficiency would give you about 2 kilowatt hours.
To store that much electrical energy would take about 120 pounds of batteries.
You see the problem?
Jan 4, 2010
1,037
We are really talking about two different uses. One use is a smallish battery to give half hour of motoring. The rule of thumb that Kenn gives works for my boat 16000 lbs 8 tons 20 kw motor which is about the same as the designed in 29hp diesel. So the rule looks good. If we tolerate 80% of hull speed then I get by with 4kw motor? since I am only running for 1/2 hr the difference between full speed and 80% speed not so important.
Now I only need 2kwh from the battery about 200 Ahr on a 12V battery if I only want 50% DOD 400 Ahr 12V battery. Not too bad and I don't think heavier than a diesel and transmission and battery and fuel setup, and maybe no more expensive?
Assuming you are content with the limitations.
Since we are talking bleeding edge stuff, you could swap out those lead acid batteries for LiFePO cells like A123 makes or in China ThunderSky. These batteries store a bunch more energy, can discharge deeper, and are lighter than lead. So now the 400 Ahr pack can be reduced back to say a 250Ahr pack and the cells are smaller and lighter than a 250Ahr lead acid cell.
Bit of untried stuff and I think Li really likes to burn so you guys try it let me know how it goes!
The next problem is range. Now we go hybrid and add a genset. Genset if we are in our 80% of hull speed can be small and if we charge from 50 to 80% will always be fully loaded, so efficient. In a normal running scenario you would e-motor out and after 1/2 hr or so the genset would kick on. Now since the power of the motor and the power of the genset are matched more or less no charging would take place, and you would motor normally. Once you were done motoring either the genset would stay on to bring up the charge or more likely you would shut off the genset and the battery would charge slowly by the spinning of the prop. At the end of the day same scenario fire up the e-motor and get back to the harbor, if it takes more than 1/2 hr the genny kicks in.
Dec 13, 2010
123
Hake 32RK Red Bank
your analysis is not complete. Many naval vessels actually employ diesel powered gen sets. They of course do not employ energy storage (Batteries). The benefit of the arrangements is that a variable frequency motor drive is infinitely variable and highly efficient at almost all speeds. The case for a hybrid system is won or lost on the energy storage componenet. The generator only runs when the needed and runs at a relatively narrow range of speed=eficiency benefit. It can be paralled with other charging methods like wind, solar or prop freewheelingwhile sailing. No one would use a 12V motor/battery in a truly optimized arrangement more likely a 250V DC motor/battery which provides for much higher energy storage capability. The biggest waster of energy in an optimized system is still going to be converting rotational energy of the prop/shaft combo into thrust and that is independent of the system driving the shaft.
There will be a premium until the cost of fossil fuels increases to its true economic value and then everyone will be wondering why we didn't make the conversion sooner.
Jan 4, 2010
1,037
Ok so here is a data point. This from Boat US mag, Torqueedo is selling a lithium manganese battery 24V 100Ahr with integrated electronics $2400 weighs 44 lbs.
This is claimed as 4x power density improvement over lead acid. How much of the 100Ahr can you safely use? In our little 4kw for 1/2 hr problem this would be enough to get you out of the harbor but not back.
So for $5k and 88lbs you get enough battery for 1hr of smooth quiet odorless motoring.
Oh and plus the electric motor. Oh and plus the genset for longer range.
Sep 9, 2010
1
Mistral 12 Union Lake
I wonder if batteries could be used for ballast in the keel? Incidentally, the Lofland Picnic 17 was sold by General Boats back in the sixties and seventies with an inboard jet drive powered by a Briggs & Stratton engine as an option. And the transom was built to hold a 40HP outboard! That was long before MacGregor came up with the idea. The Picnic was a forerunner of the Rhodes 22. There are photos on my website. <www.rvharvey.com/picnic.htm> Ralph
