The way some boat yard workers do wiring and the way some DIY's do it, with no regard for over current protection, proper wiring techniques and improper use of equipment not meant for marine use, I find it surprising more marina's are not burned up.Ouch!
Not that bad things don't also happen to boats on moorings this report makes me glad we keep ours on a mooring.
What a loss.
To which I responded:Great time to have little talk with local marina about a good electrical inspection.....??
That's exactly why arc-fault breakers are required in the new building electrical codes.Sometimes overcurrent protection doesn't do what we want. I once took the cover plate off a duplex outlet on a stone column outside of a house. When the cover came off the recepticle fell into pieces and struck an arc that burned until the wires fell apart far enough to break the arc. probably burned for 15 seconds. Never tripped the circuit breaker. That was a well installed 15 amp 120 volt circuit that had just gotten too old.
My mantra is "Its a good day if I learn something new " and I've learn a lot about boat wiring and systems from Stu and MS so I'm one of those old dogs that can learn new tricksI am truly thankful for people like Maine Sail and Stu Jackson. My boat's wiring is a lot safer because of them.
As a liver-aboarder, I am also very thankful for my concrete and steel docks. What a night mare it would be if the only escape route out of a floating inferno was over a bunch of burning and charred embers during the winter when the water is very cold.
I concur....sometimes I wonder how someone got there credential's and I'm a firm believer in keeping up with the current National Electric codesJust to add a couple of comments.
Also, too true about shoddy wiring practices...but it is up to us to be informed enough to recognize them...I had to do a lot of correction of shoddy work done by licenced electricians over the years in my 1925 home and had to point out code deficiencies a couple times to licenced (bonded and insured) electricians that I hired to do some work.
I get a hoot out of walking past this big-*ss power cruiser everyday and watching the AC discharge water freeze up more-and-more every day. Last winter it froze solid and is probably what caused the dock recepticle to burnout. (I saw them replace it during the summer when the owners arrived.) It was many months that his heating and cooling was down because he only visits the boat owners make to their boat is just a few times a year. He's never learned his lesson. I must confess though, if I was filthy rich I, too, would have boats in multiple locations and would only visit them occassionaly.One day a couple of summers ago a newbie showed up on the dock and he was never there but his air conditioner was running 24/7 I happened to notice one day that the power inlet going into the boat looked a little black and the fiberglass looked melted so I shut the breaker,a week or so later the owner showed up and learned a valuable lesson and how lucky he was that day.
A burned out receptacle may not trip a circuit breaker especially one thats been exposed to the salt water elements and that same burnt up receptacle at the boat side could heat up the fiberglass and what I'm saying is a fire could start and thats how marinas and all the boats go up in smoke very quicklyI get a hoot out of walking past this big-*ss power cruiser everyday and watching the AC discharge water freeze up more-and-more every day. Last winter it froze solid and is probably what caused the dock recepticle to burnout. (I saw them replace it during the summer when the owners arrived.) It was many months that his heating and cooling was down because he only visits the boat owners make to their boat is just a few times a year. He's never learned his lesson. I must confess though, if I was filthy rich I, too, would have boats in multiple locations and would only visit them occassionaly.
