ThanksUsing the pictures of the keel is fine. They seem to be from Macgregor and did not start out with me; so I don't know who should get credit.
thanksBy the looks of the pits in the plates I think the metal is aluminum.
Stainless should have noticable weight to it.
I've got two different types of rudders, so maybe I can help clear this up.
My earlier (1980) Mac 25 has a rudder that appears to be two fiberglass pieces, joined together by an aluminum plate. Each piece has a cutout.When the rudder is fully extended, the cutouts mate up to each other.
My later Macs (1984 and 1985) have the upper part of the rudder made up of an aluminum shaft. The lower section does not have a cutout in it, as it doesn't need one.
If the upper half of your rudder is made of aluminum, I suspect that the assembly is of a later type.
Am I close?? Perhaps a pic of the entire rudder would be helpful. Meanwhile, I will try to get some pics of the two different rudder styles on my boats.
Just remember that what ever you come up with it must be able to fold 90 degrees to launch and retrieve the boat from the trailer.
I emailed them and the guy said it was not one of theirs. Thanks for the pic, that's where I'm heading with this. The only thing I can get seems to be local oak so Im going to just build a new one and glass it. Found dimensions so it wil be OK.Your rudder should look something like this but I suspect the lower is really a Idasailor part because of the leading edge.
http://community.webshots.com/photo/fullsize/1230627810049039029qTTqcZ
Or find a temporary second job and buy one from IdaSailorI keep trying to find proper materials and I'm just flat out in the wrong part of the country........Then once I get to the coast make a real one out of wood. :bang:
That thought keeps popping into my head. Will it hold up over the long haul if I'm very careful and make sure all exposed surfaces are well epoxied?If you are going glass over it why not jus use exterior plywood?
The budget is your typical shoe string.You do not mention what kind of budget you have to work with, so I do not know your limitations in this matter.
You might want to check out this ad on CL:
http://losangeles.craigslist.org/lgb/boa/2151681088.html
He is offering a rudder and tiller for $150. Maybe you could work out a deal to have him (or someone on this forum) ship it out to you.
Just a thought.
It's a nice idea if things worked that way.Or find a temporary second job and buy one from IdaSailor. Sorry I couldn't resist.
I can understand that. Most of my adult life the only boat I've owned has been a Grumman canoe and I had a hard time scrapping together $150 for it years ago.It's a nice idea if things worked that way.
