Replacing Motor Mounts / The Snowball Effect
11,721
I get lots of comments on my site to the effect that I make these jobs look too easy. They are easy.;) It does not mean they don't get frustrating, tedious and maddening though! Yes, we all face the same obstacles when working on sail boats and there is no way to get around that.
This post is reminder of how boat jobs often go awry with one problem leading to, or unmasking, yet another. I call it the SNOWBALL EFFECT.:cussing:
This job was to be a simple shaft, cutlass, coupling & prop replacement but oh how things change when you get going. The boat, a mid eighties Ericson 34, has relatively low engine hours for her age but exhibited a very high level of vibration.
After I pressed out the cutlass bearing it became very apparent just how badly the vessel was misaligned.
Not only was the engine sitting far to low in the shaft log, and the shaft was thumping it when the engine was in gear, but it was also not passing through either the shaft log or the cutlass even close to parallel. The minute the cutlass came out the shaft sprang up and pressed into the top of the strut. While boats can lose some alignment out of water it is usually in the measured in the order of thousandths of an inch when measured at the shaft coupling. My own CS looses about .001" from in water to out in terms of alignment and she has a significantly longer shaft. This boat has a fairly short shaft and robust engine bed area so flex was clearly not causing this level of alignment issue. Read on and you'll find out the real reason this motor was so badly aligned.
When we got the new shaft in place I wanted to adjust the engine first to do a rough alignment. Ericson, in all their infinite engineering wisdom chose a three point motor mount system for the Universal M-25 diesel. Three mounts is not the norm in boat building and almost all engine manufacturers ship engines with four mounts, generally with good reason.
The minute I put a wrench to the front mount in order to adjust it and thus drop the shaft from impinging on the top of the strut, the mount stud simply began to spin in the mount. In the marine environment the studs can get rusty or in this case the threads also get mashed and the stud with this type of design breaks free from the rubber it was molded into. Bad design for boats in my humble opinion. It was clear quite quickly the boat needed at least one new mount but I advised the owner to order three new ones and gave him the part numbers.
One thing I often see that destroys motor mounts prematurely is the lack of properly tightening the stud nuts that clamp the motor mount bracket. If these nuts are allowed to become loose the motor mount bracket or bell housing ears will vibrate over the threads and wear them away to nothing. All three of the mounts on this Ericson 34 had badly worn threads. Worn threads will prevent any future re-alignment and require new mounts whether the rubber is ready to be replaced or not. One of the mounts was still in operable condition had the threads not been destroyed by letting the nuts come loose. The other two were toast and both spinning in the rubber.
In order to replace these mounts with a different model or brand would have entailed a far more costly and time consuming job due to differing bolt centers for the mounts. The red Westerbeke mount pictured below is a FAR SUPERIOR mount to the older ones used on the M-25's. That red one has 3000 hour on it and other than a little "sag" was still technically "usable".. The failed mounts with bolts spinning free had 427 hours on them... Doh'!!!!!:doh:Still the owner opted to stick with the same mounts due to the costs and time associated with re-vamping the engine bed for a new bolt pattern.
The three point design of the Ericson motor configuration is also somewhat dependent on the rather stiff lateral design of these original mounts. It was decided, though not happily, to re-place these mounts with the same brand & model.:doh:
Yes, this simple shaft & cutlass replacement turned into a total comedy of errors. This was the starboard rear mount. It had been broken for quite some time as evidenced by the mushrooming of the sheared stud. With one failed mount, in a three point Ericson design you are now left with just two mounts holding a 350+ pound engine in place, scary! If there had been four mounts and one broke, not as big a deal, you'd be back to what Ericson used every day, but with just three motor mounts...well... it is what it is.
This was the sheared stud. It had obviously been broken for a while as evidenced by the mushrooming of the stud. Broken mounts are not all that uncommon in Maine as we have lots of lobster traps to snag a motor and stall it by stopping the prop. Sometimes the shaft bends, sometimes the prop, sometimes the gear box fails and sometimes a mount fails. I can't say what caused this mount to shear but I can say having only two mounts left, when one fails, is a little scary.
The red mount on the right is an older style Westerbeke/Universal engines factory motor mount. They are well designed, robust and do a very good job of isolating vibrations despite their rather expensive price tag. That red one has 2782 hours on it and the two failed mounts to the left are low hour mounts that had already been replaced once before. There are features of the Westerbeke/Universal mount that make them well worth the money;
1) You can not twist the stud inside the mount because it is welded directly to the mount cap.
2) The feet are encapsulated in molded rubber helping minimize noise and vibration transmission.
3) The metal cap prevents engine oils from eating away at the rubber by shielding it.
In short I am not a big fan of the two mounts to the left and I have seen the failures repeated prematurely a number of times.
I'm not kidding, and yes it just keeps getting better, or worse depending upon how you look at it.;) This picture is one darn good reason why I detest "Ideal" style or perforated hose clamps. This was the hose clamp for the stuffing box hose. Two out of the four literally fell apart the minute I touched the screw driver to them. Yes, scary!!
Because the perforations make the center of the clamp softer than the edges, due to the removed metal for the perforations, they can bend upwards and away from the screw threads over time. The screw on this one literally fell out of the holder and yes, they were marked "all stainless". These hose clamps were keeping this boat afloat and thank God there were four!
Please use non-perforated hose clamps for your below water connections. I prefer the AWAB brand and have never once had one fail and I have seen buckets full of the perforated style fail.
Whew, finally getting to the actual replacement of the mounts which is actually quite easy. To make this task easier I use my favorite scissor jack. This jack came from a Honda CRX I owned in high school. I loved it so much I kept it when I sold the car. This little jack folds to about 2" tall making it easy to slide under even the lowest motors. These can be found in junk yards and will be the best $5.00 you ever spent.
There was yet one more problem with this installation the stud on this front mount winds up behind the lower crank shaft pulley. When the boat is put in gear and the motor moves slightly forward under load the studs threads grind on the back of the pulley. In order to prevent this the stud needs to be cut shorter to clear the pulley once the engine is in alignment.
When jacking a motor be sure that any hoses, refrigeration belts or other items that can impede the raising of the motor are disconnected. You'll also want to loosen but not totally remove the top nuts on the other mounts to facilitate the motor being lifted enough to get the mount out. Removing the old mount and sliding this new one in place took all of about 10 minutes.
This engine room has very tight access on the starboard side. In order to remove the motor mount lag bolts I used multiple socket extensions, which made this a quicker and easier job.
For a 34 foot sailboat this engine room is quite loaded with gear. She has Sea Frost engine driven refrigeration, fuel filters, water heater hoses, upgraded alternator and many other non-standard features that make working in there tight. The small jack is critical on engines like this for replacing motor mounts.
The camera angle makes this area look a lot more roomy than it really is. The scissor jack fits nicely between the engine bed stringer and the engine and is lifting in-board of the motor mount hole but using the motor mount bracket to jack the engine. This is a good illustration of why this little jack has stayed in my tool quiver since 1985..
Here is another shot of the scissor jack. I collapsed it entirely and slid it in through the transmission opening in the bulkhead. You need to be careful and use mirrors to make sure you are not jacking on the oil pan or any sending units, hoses or fragile brackets. Oil pans can be used on small engines but I would advise using a block of wood to spread the load. If your oil pan is rusty please do not use it or you may punch through. If possible always use the mount or another strongly supported area of the engine.
Lifting one corner of an engine is not a lot of weight. The weight is so little that I can usually twist the jack screw by hand with no extensions or tools. With the other mounts loose it is very easy to lift one out. If you can get a good jacking angle and find enough support you can lift in the center and raise the front or rear and do two front or rear mounts at the same time.
Yes, believe it or not I discovered yet another problem. Once all the new mounts were in place I began to do a rough alignment of the motor to the shaft, cutlass & shaft log.
For some reason the I could get close but she just kept popping back out of alignment no matter how I moved the engine. After 20 minutes of mucking with her I realized why the engine was so low to begin with. A previous owner had replaced the exhaust elbow, a whole other set of problems, and made the nipple between the manifold and the exhaust elbow to darn long.
To correct for this mishap they Mickey Moused it by simply lowering the engine so the exhaust outlet cleared the bulkhead. This fixed the exhaust issue but caused many more as you'll see below.
As I said this entire project has been a comedy of errors. Either the previous owner who did all this work was a really bad DIY guy or he hired the worst mechanics on the planet. There was no reason for this exhaust elbow to be tilted off center other than the fact that the installer refused to use pipe dope to mate the NPT fittings together.
It probably bound up and refused to turn anymore so they just left it tilted off center. Due to this laziness, or lack of understanding, it caused the exhaust elbow to chafe, vibrate, dent and make a career ending thin spot in the heat exchanger. Cha-ching $$$$ more unnecessary expense for the boat owner $$$$. Had someone done this job right to begin with he would likely not have needed a new shaft cutlass, motor mounts, heat exchanger etc. etc. etc...
This manifold will fit and will clear the bulkhead & heat exchanger when installed correctly, it was not.
As mentioned the exhaust elbow was a disaster of an installation. Who ever did this install knew nothing about thread sealants or pipe dope. It took hours of soaking with PB Blaster, some heat, a massive bench vise and a 3.5 foot 1 1/4" black iron pipe as added leverage to an 18" Rigid pipe wrench to break these fittings apart. Due to the improper installation of these threaded fittings they had been leaking early on and thus rusted together as strong as I have seen in a long time. PB Blaster is great but when you are dealing with sealing threads, such as NPT, that are meant to keep fluids out, they also tend to keep most of the PB Blaster out too.
This exhaust flange fitting is a $90.00 part from Universal so I clearly wanted to save it for the owner.
So after many hours of soaking and a very long pipe on the end of a very robust pipe wrench the nipple finally gave up its hold. The force needed to remove it from the exhaust flange crushed and made it oval.
This is what my 3.5 foot black iron pipe looked like after I broke the stuck fittings free. I have not done the calculation on how much force I applied but all my 200+ pounds were going into that leverage pipe and the fitting was over 4.5 feet away away from the end of the pipe.
The owner was already into this job for a new shaft, coupling, cutlass bearing, three motor mounts, Ultra-X packing, stuffing box hose, four AWAB clamps, a heat exchanger and various nuts bolts and hardware. I really did not want to have him absorb the cost of a new exhaust elbow and flange on top of all this for just for a few stuck fittings. This would have been about $300.00 worth of additional parts but I was able to clean, paint and re-use them.
I was able to take nearly 2" out of length out of the nipple between the exhaust flange and the exhaust elbow. This will allow the elbow to no longer hit the bulkhead and to also clear the new heat exchanger. I used a street elbow for water injection which allowed the assembly to be shortened.
This exhaust elbow is not a Universal Engines genuine part hence the reducing bushing from 1 1/2" to 1 1/4". Gotta love the snowballing effect!
The motor mounts were the easy part of this job. It is all the little things you find along the way that make the job take longer and really get frustrating. for example getting the exhaust elbow off the engine required the engine to be completely lifted off the mounts and moved forward. We used a 4:1 Harken block & tackle to a beam across the companionway for this. This little extra step added almost an hour to the job alone.
So a simple shaft & cutlass replacement led to; three new motor mounts all failed, removal & reconfiguration of the exhaust elbow, a new heat exchanger, failed hose clamps, engine antifreeze flush & fill and more. This is a much more typical job than it would seem and this sort of snowballing effect happens quite often with boats. See, it's not always easy...
So far this job has been an excellent example of the SNOWBALL EFFECT and it's not even done yet!!;);)
P.S. Next time you are not DIYing your own boat repairs and you are unhappy with the labor bill from the yard come back and re-read this post.;) Sometimes no amount of planning ahead alerts you to the hidden problems that lie waiting..:)
jimmyb
Feb 12, 2010
231
Precison 165 NA
Maine sail,
As a former motorcycle tech and a long time hot rodder I always appreciate the thourough assesments and follow through you preform on the jobs that you post. I was the same way and although it may have cost me a few bucks on flat rate I rarely had to deal with jobs coming back on my lift. Hats off to ya for quality workmanship and covering all the bases.
jimmyb
Ross
Jun 15, 2004
14,693
I am relieved to know that this was someone elses boat. I knew you had just replaced the bell housing on your engine and couldn't imagine how the engine mounts ahd gone so bad so soon.
I had a friend dead now for 15 years who had married the duaghter of a plumber. He said he had once asked his father in law if you really needed pipe joint compound on npt fittings. He said the old man told him , Only if you want to take them apart later."
I am surprised that the heat exchanger didn't collapse under the clamping in the vise.
PeteK
Nov 3, 2008
30
Clipper CM4/c Nordland, WA
Good post Maine! That is exactly why I don't let other people work on my stuff; I hate fixing 'snowballs'.
Pete
Macgregor 21 MN
When the threads get this bad I like to saw into the pipe to be able to compress it enough to loosen the threads as one attempts to turn it. I try to be careful not to compromise the parent threads.
It is interesting how one job leads to another. Pretty soon you have a new Yanmar sittin' in the engine compartment! :D
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
"after many hours" of labor you were able to save a 90 dollar part. Doesn't seem like a reasonable approach. Say your labor is 50 bucks an hour (most yards charge a lot more) the part is cheap in comparison. I guess you didn't want to wait a week to get the part. Be careful when hanging on a pipe wrench and a long cheater, if the pipe broke or the wrench slipped you could get hurt, another reason a new part is a better deal.
You might want to tell the owner to replace the control cables also, look pretty corroded.
How are you feeling after working as a contortionist all day. A much better slide show would be one showing all the strange positions you had to get in to do all this work trying to put leverage on wrenches using muscles in new ways. I'll bet you'll be sore for a week. I went on my buddies Selene trawler a while back and you could walk around in the engine rom, almost standing up, easy to get at everything, it made me sick to my stomache.
Great post MaineSail, I have the same engine ( and have seen some of the same problems over the years) hope you recover quickly and another boat fixed right!!
Ducati
Nov 19, 2008
380
Boatless Boatless Annapolis
Great post + photos.
In the end the right thing to do is always the right thing. That is, fix it properly and learn some stuff about your boat at the same time.
Hope that is the last time you have to deal with something like that.
615
Morgan 415 Out Island Rogersville, AL
Reading all your posts, Maine, is causing the value of my boat to go up ;-)
Jun 7, 2007
515
Hunter 320 Williamsburg
Aaaggghhhh!
Good Gawd Almighty, this is why men take up bowling.
Friend is being quote 7k by the yard for a shaft job.
Now I know why.
11,721
Now I know why.
That is a "shaft job" if it's just a small sailboat shaft.;)
So far:
Aqualoy 22 Shaft, split coupling, fit & face, nuts, keys = $425.00
New HX = $300.00
New Mounts = $225.00
Manifold Gasket = $5.00
Antifreeze = $15.00
Plumbing Fittings = $32.00
AWAB hose clamps $18.00
Misc. Hardware = $30.00
Cutlass Bearing = $52.49
Spray Paint = $6.00
Prop = TBD
Stuffing Box Hose $8.00
Total Parts = $1116.49
Labor = 11 @ 72.00/Hr = $792.00 (still have a few hours left to go)
Total projected job cost $2200.00 +/-
Where are they getting the other 4-5k?:doh:I'd have a hard time adding that one up.
Dec 25, 2008
1,580
catalina 310 Elk River
Cause and effect.... you see a problem, likely there are more, and then finding the underlining root cause is where the art of trouble-shooting is.
11,721
Many hours of soaking in PB Blaster, not necessarily trying to get it apart. I brought the part home and spent about 45 minutes total on in including heat, PB Blaster, pipe fitting, cleaning & painting. Made about six attempts on it over four hours @ about 2 minutes each, and she finally broke free. So about $54.00 in labor to save $300.00+ in parts, which does not include any shipping costs. A net savings to the owner of roughly $250.00..
I spent almost 15 minutes searching for my "breaker pipe" and Rigid pipe wrench but I can't charge the owner for my disorganization now can I.:doh:
Jan 27, 2008
3,086
where did you get the heat exchanger for 300 bucks? I want to upgrade to the 3" diameter version, still have the original 2", and have seen prices closer to a grand.
Another way to deal with a stuck thread is to put it on a lathe or Bridgeport and bore it out until it becomes very thin without wrecking the threads, then what is left you can just peel it out by using a cold chisel, very similar to the way you showed us to cut a cutlass bearing and then collapse it. We used to use this method with sleeves in aluminum housings to salvage the housings if the sleeve was bad.
I had a yard replace my exhaust at one point and they did the same thing as you to save the flange on the exhaust manifold. The bottom stud on that assembly is also a nightmare to get at in my installation. I can't get a socket on it as it is too close to the exhaust pipe and insulation so I have to use a wrench and can only turn it a small amount each time then turn the wrench over take another partial turn, etc. All while laying down in an odd position. Getting tough for an old geezer like me. :>)
11,721
I have my sources...;) Will send you a PM.
1,096
CS 30 Toronto
Maine Sail,
Do you know where I can get a fresh water cooling conversion kit for a Volvo 2002?
I have CS30 and plan to take she south in Salt water.
