I think the 'jam some shims in the tube' fix are to remove sloppiness from tube wear over the years..I do not think it will solve the leaky stuffing box problem. I would assume most owners wouldn't even know the sloppy tube problem existed unless you are like me and have tiller steering and can feel the rudder shaft flop around in the out-of-round rudder tube. The other fix for that is to build 'bearings' into the tube by injecting graphite filled West System epoxy. This is pretty much the same fix as detailed in the PDF from Jeff's link above (
http://www.catalina30.com/TechLib/Rudder Shaft/rudder-repair.pdf) , but I'll be contacting the West System guys and using their products..apparently the graphite in the epoxy helps to act as a lubricant for the bearing you build during the injection process (kinda like graphite powder on pinewood derby cars, in your key locks, etc.)
Max Munger (the Stu Jackson of C-30's, class treasurer & at some point the Catalina 30 website manager) over on the C-30 Yahoo group would be able to confirm this. I think they are two separate 'problems'.
edit - after re-reading that PDF it looks like the 'epoxy injection' method will also seal a leaky tube if you follow their instructions (reference page 5 of the PDF) & page 10 has wheel steering detail.
