Just redid my sanitation lines aboard my Hunter 33 (1981) with all new 1.5" sanitation hose, etc, from toilet to through hull, including holding tank and Y valve.
Also swapped out the 1.5" Vented Loop (siphon?) -- the old stuff was original, cracked and rotting, plugged, etc...
I have the system connected as per the standard setup (see attached)
I am noticing a slight squeak when I pump the clean new system. It is coming from the "duckbill" valve at the top of the vented loop. It usually occurs towards the end of the flush. Just been flushing water at this point.
Any ideas, suggestions or advice will be gratefully appreciated.
Many thanks
Bob Pullen
S/V Seanorita
Mexico
Many thanks
Bob Pullen
S/V Seanorita
Mexico
