How would you rig a bridal for a drogue on your stern that you wanted to use as an emergency steering aid? Has anyone done this?
You could use your spinnaker sheet blocks if they're mounted on a genoa track where you can set them all the way aft.How do you keep the line from chafing? Do you have blocks on the stern that the bridal runs through before coming to the winches?
I've carried two 100' lines in 5 gallon buckets to deploy them for practice steering. My problem is it never comes to mind when air fills the sail. Shame on me. However I never think a great white is going to bite off my transom either. I've read books that ASA and US Sailing have on their website about chafe and thought the same as you. If you're steering with a drogue I would think you would have to adjust the position of the bridle along the transom to maintain your heading. Hummm, plenty of variables.How would you rig a bridal for a drogue on your stern that you wanted to use as an emergency steering aid? Has anyone done this?
I read Maine Sail's post on chafe and pendants and have been wondering why the chain we use on anchors for chafe can't be used on the other end? Some protection is needed and rust is always a concern, but in dire need it doesn't chafe that much. Hmmm, maybe this has been tried on drogues. Several variables, what do you think?I just finished reading a book called "The Boats They Sailed In". It chronicled 9 classic (famous) ocean voyages in small boat starting with Joshua Slochum and ending in 1983. Instead of a focus on their adventures, the book focused on their boats. It detailed gear, rigging, performance etc. One of the disturbing themes that repeats in each voyage was the loss of their sea anchor to chafe during a big blow. As I've been thinking about a trip this summer off of the DelMarVa coast I'm considering placing U-bolts in my stern with an oak beam as the backing plate so I can secure a drogue or sea anchor with a very heavy snap hook. I think that if things really got bad enough that I needed a drogue or sea anchor I don't want to worry about it pulling out my genoa track... or the chafe that a block would provide.
Admittedly I'm speaking from zero experience using such a device in a gale. I have used a drogue before but only when I'm swimming and don't want the boat to drift to fast.
2 cents
Are you taking your V222 offshore?... Why don't you use the winches to carry the load guided through some blocks on the stern quarter. If you think you'll encounter weather strong enough to yank a drogue out of the cleats... what's too keep the same storm from yanking out the transom.
A drogue doesn't stop the boat, it is deployed aft to slow the vessel down. A sea anchor is deployed from the bow and its main purpose is to keep the boat relatively static, facing the wind and waves at an optimum angle of comfort and safety... similar to heaving to. Chafe control is part of every offshore sailor's ongoing chore. The key is vigilance, and plenty of anti chafe material.
