Head lubrication
79
Hunter 29.5 Big Ridge Marina, Hixson, Tn
Head Mistress,
I just got your book. Great reading. ( I can't believe I said that, but true) I have the Jabsco standard manual toilet installed in my Hunter 29.5.
Question: What type of Teflon grease would be the best to use for head maintenance? Spray, tube, and do you have a brand that is better than others?
Thanks, healeyman/Dave
Dec 2, 1997
9,010
- - LIttle Rock
I dunno of any thick greases that can be sprayed, so I think you'd better look for it in a tube. :) And as Rick said, SupLube is considered the best. Follow the link he posted to find it.
Glad you find the book useful.
RichB
Oct 8, 2006
87
Hunter 23 Winter Park, Fl. h23
Just passing through... and I haven't used it yet but I understand vegetable oil is a safe way to lube the pump. I ruined one rebuild kit with synthetic grease. (The rubber expanded)
Now that I have written this.... I notice I am jumping in with the Head Mistress..... So where do I apply the Super Lube???
Dec 2, 1997
9,010
- - LIttle Rock
You must have used a petroleum grease
Petroleum is HIGHLY damaging to rubber...which is why Vaseline is a bad choice just about anywhere on a boat.
I could tell you that you'll find out where to put the SuperLube if you buy my book...but that wouldn't be nice...and besides, I've posted it here a ziilion times. So here it is again: Remove the top of the pump...stick the nozzle of the tube into the pump and give it a healthy squirt. Pump a couple of times to spread it all over the inside of the pump...replace the top...you're done. Takes all of 10 minutes if that long...and unlike veggie or mineral oil, which has to be added every week or two, you only have to do it once a year.
You might want consider buying my book anyway...'cuz there's a whole bunch of other good stuff in it. Click on the link in my signature to see what it includes.
