Re: Lead Keel
Towfoot:
I also have a 2007 373. If you research a bit more I believe you'll confirm that it is a cast iron keel. From discussions with Interlux I've learned they developed the factory finish program.
I had a few minor rust blooms show up after my first year. The local Interlux rep was nice enough to inspect in detail and based on his advice, I took the keel finish down to the factory white finish, blasted the blooms down to cast iron, and applied about 7 coats of Interlux 2000 2-part epoxy. The result, no problems over the past 4 hauls.
