Hi,
Just wondering what the consensus would be on the largest hole you would feel comfortable with patching with an epoxy, micro-balloon, silica mixture?
I removed a capped thru-hull from my transom and want to seal the opening. I am putting 5/8" epoxy-coated plywood on the inside of the transom and glassing it in place. I was then going to put a good vertical mixture of epoxy in the holes from the outside of the transom.
Can I do this with the thru-hull hole or should I build up glass from the inside? The plywood will be the physical support no matter what.
Also, what is the best way to remove silicone from the fibreglass? The PO embedded everything on the transom with it (including the insides of the holes in the fibreglass).
Thanks
Thanks
