I have a 2000 B321 w/a Yanmar 3 gm 30 F. What size is the shaft 25mm or 30mm ? Do you use one along with the one on the end of the prop ? Mine is used up before 2 months has passed and would like to use a collar zink if it is possible.
I have a Beneteau 281.. My shaft does not have enough room for a zinc, but fellow 281 owners do seem to have room.. I guess there is some variation in the prop shaft lengths - some have room for a clamp-on zinc on the shaft, others do not.... good luck !!
