Lady J, week 10.5, almost too busy to get up here...
1,140
Knutson K-35 Yawl Bellingham
It's been a while since the last report as we've been busy but here goes. After looking at options for the transom, which is ratty plywood, I settled on covering the ply with a nice, figured Honduran Mahogany veneer. We cut it to fit using a template, spread thickened epoxy and placed it. It proved to be difficult to get the bubbles out and the edges flat with such a large piece. This is how it looked after we finished applying it.
We still had to add more bracing to get the edges flat.
The next day, I checked it out and didn't like it. From five feet away it was fine but I don't tolerate that. We peeled it off with heat guns and putty knives. Needless to say, it wasn't a painless process. I spent the next two days repairing the damage.
This time, I'm going to separate the planks in the veneer with heat (I found this when taking the other off) and lay them up individually. This should be a more manageable process.
The boys have been busting their humps on the brightwork both inside and out. They finished prep on the exterior and I applied CPES prior to varnish.
and
The interior is about 80% prepped and will gert coated this week.
and
My new detail guy is terrific. He takes some of the load off of me.
There's still a good bit of interior parts to be done.
and
During this time, the owner decided he didn't like the look of the seam compound as some of it had soaked up stain and other parts hadn't. He disliked it enough that if I couldn't fix it, he was ready to paint the boat instead. After some trial and error, I came up with something that worked. He was happy and here's the result.
Of course it will turn amber with the varnish but as long as it's uniform, that's cool. Another issue popped up with the mast. It continued to separate at the seams just sitting level on the rack so we decided it was time to rebuild it. Here's a series of teardown pictures. Trust me, this isn't for the faint of heart...
Yesterday
This morning
Tonight
Some of the seams popped cleanly
Some are ugly and will require a lot of work to get straight and clean
Where the old resourcinal held up was impossible to separate and had to be sawn. I'll likely have to scarph in a bit along that area but that's ok. I lined up some old growth Sitka Spruce today in case.
Finally, there was this little bit of fairing for the depth sounder from Sapele that I carved on the bandsaw. I like it...
Ross
Jun 15, 2004
14,693
So why do some people say that a plastic boat isn't worth spending some time and money on to make her new?
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Charlie,
25+ years ago I restored a 1961 Chris Craft Constelation.....it was a labor of love and after looking at these pictures it brought me back in time.....Love it
615
Morgan 415 Out Island Rogersville, AL
Another awesome installment. Thanks for taking the time to document your work for us.
Feb 8, 2007
141
Catalina 36 MKII Pensacola Beach, FL
Beautiful work. I wish I had skills like that.
You ought to get one of the magazines to come do an article on it.
Ross
Jun 15, 2004
14,693
Charlie, How in heavens name do you estimate the cost of a job like that? I hate to be constrained by deadlines for completion or by budget for cost. Somethings are easy to estimate but other jobs have so many unknowns and can't see problems until you can uncover them. You could have spent a month surveying and not seen all of the details that you want to correct.
Your attention to detail is laudable and very rare in today's hurry up and get it done world. I have been working for a man who has "I want it done right, I want it done quickly, and I want it done cheaply he says because I am not made of money as he gets into his Escalade to go buy the crew lunch.,
Apr 29, 2010
209
MacGregor m25 Erieau, Ontario, Canada
Did you ask him which two he wanted? ;)
May 5, 2006
1,140
Ross, I drive a sweet running beat up '72 Chev 3/4 ton. No Escalades here. I bid these jobs by phases with the understanding that there my be hidden issues, especially with structural work. I'm not always on with an estimate and if I'm not too far off, I eat the difference. If I blow one, I talk to the customer about it before I exceed the estimate, usually well before. My estimate for this job was several pages with spreadsheets attached. We did have 13K of overruns for unforeseen work on the hull and another 8K in additional customer requests. All overruns were approved prior to the extra work starting.
Ross
Jun 15, 2004
14,693
I commend you for your careful planning. Every now and then I miss calculate a seemingly simple job that should take me a day and it takes three and I just plod along and do the job right and acknowledge that the owner got a bargain. You plan for weekly draws against the progress of the work?
I will get up some pictures of a wheel stand for power tools that can be lifted and set down by one man using just one hand.
May 5, 2006
1,140
Yep, on a project like this I pre-bill the estimated hours and materials for a time period, either one or two weeks. I keep a running total of hours on each phase or charge-line and the amount of funds left in the customer's account. When it goes to a negative and becomes an actual account receivable amount, I prompt for funds. I can tell the owner at any given time the amount of hours on each charge-line, the dollar amount, percentage of work remaining, hours remaining and a moving projected total. The boys log every hour in each charge-line through the day, changing the charge-line when they switch jobs. I can tell how much money in labor is left in a job and tell them when they are reaching cutoff. Eventually, I'll write a database app for the entire process but for now, Excel will do.
Ross
Jun 15, 2004
14,693
your experience may result in a consulting opportunity for other people in the industry. Most of my jobs are less than 50 man hours in total.
May 5, 2006
1,140
Possibly. I've done Project and Program Management in other fields before. This gig is gonna hit right at 800 shop hours and maybe 3000 man hours before it's done.
Ross
Jun 15, 2004
14,693
I get quite a few calls from homeowners with a long list of needs and it becomes apparent that I am not going to get the work when I write down every detail of the work and then send them a detailed estimate for the total job. I think they are looking for someone who is optimistic about how quickly and easily they can do what I see at 30 hours of work.
Aug 2, 2010
563
J-Boat J/99 Cobourg
I am in the cabinet business and a competitor of mine one time related a concept I use to this day. We all know the expression PDQ which usually means pretty darn quick. He says that stand for Price, Delivery, and Quality. The standing answer now is we can make a deal if you the customer want control over just two of those. If you want control over all three then we cannot find a way to work for you!
Dan
Ross
Jun 15, 2004
14,693
Charlie, what is the latest on O-Joy? You were making great progress on her when the train went off the tracks and you had to re invent yourself.
