We recently launched and retrieved Verboten, our fin keel tall rig Capri 22, at the Gleason ramp on the Columbia River in Portland, Oregon. My trailer (see pic below) has 4 raised pads and a skid for the keel. We also have 2 dolly wheels on the front of the trailer so we can launch/retrieve the boat at the end of 30' of straps.
This was my first time at the Gleason ramp which is quite a bit longer, and steeper, than the ramp we normally use at Fern Ridge Reservoir. Launching was, as usual, simply a case of getting the trailer deep enough for the boat to float off the trailer.
When the boat is properly placed on the trailer about 3" or 4" of the skid extends behind the keel. When we pull Verboten at the lake the keel is usually completely on the skid but needs to be pulled forward with a come-along and one of the tow straps. What I saw when we pulled Verboten out at the Gleason ramp was downright scary - only about 50% of the keel was actually on the skid! Once we got to the top of the ramp and hooked the trailer to the hitch I was able to pull the boat forward and heave a huge sigh of relief.
A couple of observations: Due to high tannon/algae content the water we sail in generally doesn't let you see much below the surface, and my bow eye and the v pad *always* seem to be hitting each other when I retrieve. Moving either is not an option I'm interested in taking on.
So, the questions: What do the rest of you do in this kind of situation? Short of diving on the trailer, how do you know where your keel is in regard to the skid? Is there a way to get the boat placed better on a steep ramp? Would running the trailer deeper than normal help?
Thanks,
Chris
Thanks,
Chris
