bulkhead
1
oday 25 lac baskatong,qc.
I've recently discovered dry rot in my bulkhead, it is an oday 25, any suggestions on how to repair or replace?
Jul 24, 2006
628
Legnos, Starwind, Regal Mystic 30 cutter, 22 trailer sailor, bow rider NEW PORT RICHEY, FL
the oday 25 is plagued with this problem. It all depends on the location and severity of the rot. On mine i cut out the rotten section of main bulkhead to just a few inches above the settee. and scabbed in a new piece of 1/2 inch marine plywood. I filled any imperfection in the joint and fiberglassed it to the existing bulkhead. This is not considered the correct fix . The more acceptable method is to replace the entire bulkhead with marine ply. I am experience fiberglass repair guy so i was confident in my fix. I also removed the chainplates from the bulkheads and filled the elongated holes with epoxy and glassed over the old holes the complete length of the bulkead and redrilled/attached the chainplated using 3m 5200 as bedding compound to protect from further rot from pesky leakage from the thrudeck situation. post pics of damage or more detailed description ad you will get more detailed answers. Pat
I sanded and painted my bulkheads off white enamel
544
Bristol 43.3 Perth Amboy
Not an impossible job to replace the whole thing
I've done this. Take a look at my link.
Ross
Jun 15, 2004
14,693
When I got my boat it had this problem so I replaced the bulkheads and moved the chainplates outboard. Why have a hole in the deck?
stx203
Oct 15, 2009
58
Oday 25 Tall Rig Fin Keel Chesapeake - Middle River, Md
I had the same issue with my 77 OD25 causing a catastrophic failure while sailing. The chainplate pulled through the bulkhead and shot thru the deck causing the mast to go overboard and snapping the roller furler. Not a fun day...spent the summer replacing the bulkheads....just got her back in the water. My advice is don't sail her until you fix the issue. See my recent threads for info about the repair.
