Zincs?
495
In search of my next boat Palm Harbor, FL
I have a Hunter 22. It has a o/b which is pulled out of the water when not in use. Should I still have zincs installed? If so does anyone know where. This boat is in Tampa, FL and sits in a slip 24x7x365.
Jul 25, 2009
270
Catalina 1989 C30 Mk II Herrington Harbour South, MD
You may already have them, the outboards I've seen have a trim tab that doubles as a zinc.
Oct 2, 2006
1,517
Jboat J24 commack
I have never seen and outboard that is kept dry when not being used use up the zincs
Nov 6, 2006
10,220
Yes you should. Go to the your owner manual or the engine manufacturer web site and find the owners manual for zinc location. You probably have a zinc on there now..
Jul 28, 2010
914
Boston Whaler Montauk New Orleans
To follow up on what Wonkodsane said, most outboards have a little fin hanging down from maybe the cavitation plate just above the prop. It doubles as an adjustment for motor pulling one way or the other and as a zinc.
Jun 16, 2010
495
So the zincs are just to protect to the motor, or are there other items on the hull that are protected by the zincs? Like bronze thru-hulls, or the mounting brackets that the swing keel is attached to?
Jul 28, 2010
914
They are there to protect any metal on the boat. On my motorboat, for instance, the motor is the only metal thing in the water, so that's what the zinc protects. Sailboats have a lot of things in the water, like thru-hulls, etc., so your zincs will help protect all of them.
zeehag
Mar 26, 2009
3,198
the engine zincs protect only6 the engine. the other zincs you place on your boat do the rest of the boat. ouboard engine zincs only protect the prop and lower end unit.
Jul 28, 2010
914
Well, I yield to Zeehag on this issue. Infinitely more experience than I have. Zee, if the outboard were kept in the water, would that not protect all the metal in the water?
zeehag
Mar 26, 2009
3,198
only that close to the zinc.. some folks drop a line with zinc on it overboard to protect those items underwater line--mostly smaller boats i have seen doing that, but i have seen an older 55 ft boat with zincs overboard on lines near thru hull fittings--looks weird. i guess it works in th e case of living aboard. i trust my prop and shaft zincs -- i have others-- taiwan plate on my rudder..large like a trawler plate only renamed l--that protects the gudgeons and pintles of my rudder...5the thru hulls are spozed to be attached by a bonding system to that---so it is different from the smaller boats that keep stuff simple...i have one of those also....
