Recommended Upgrades H23.5, H240, H26
Since I am moving up to a H33,and selling my H26, I have compiled a photo list of my favorite options/upgrades. applicable to the H23.5, H240, H26 boats. Some are merely more convenient, others essential.
Number 1, on my list is the IdaSailer rudder system, it is far superior to the factory system,and well worth the expense.
Number 2, would be the extra long shaft extension outboard, with alternator for re-charging battery. In heavier seas, prop stays in the water.
Number 3, was still on my wish list, electric tilt, and remote engine controls. Ease of docking and in heavy seas, leaning out to deploy motor was not my favorite, Admiral could not raise 9.9hp motor.
Number 4, is the BoomKicker, eliminates the topping lift, makes life easier, especially when deploying the Bimini.
Number 5, the Bimini with cover, but needs a window to see the masthead wind vane.
Number 6, 5 gal capacity Porta-potti, only if you do 2-3 day cruises.
Number 7, Stern Rail seats with adjustable length tiller extension, increased visibility forward and fun factor.
Number 8, Spinlocks for jib sheets, we never have to use winches for jib.
Number 9, Furling Jib, could easily be number 1 on list.
Many others are tied for 10 spot, some advantages are not obvious, e.g. the PowerThruster also keeps prop away from dock and rudder.
The bow roller and rail mount for anchor make that chore much easier, especially for the Admiral.
Wichard shackles, for halyards and sheet make your life easier.
Masthead mounted VHF antenna, masthead Windex wind direction indicator.
Lazy-jacks, Sail cover, jib cover.
Digital depth with speed indicator, bulkhead mounted compass.
Circuit breakers, DC power point.
LED anchor light saves battery during overnight anchorages.
Hatch board storage locker.
Rail mounted propane grill.
Added storage shelves and other devices.
Stainless Disc Brakes for trailer are easier to maintain, and never have to be unstuck like drums where every spring.
Since a picture is worth a thousand words, here is photo link, which also includes some pictures of our favorite moments sailing, which is after all why we sail.
http://picasaweb.google.com/clarenc...?authkey=Gv1sRgCIb5-YWKo9ahJw&feat=directlink
Adding all of these to any boat can be expensive, my advice is to sell a less equipped boat and buy a well equipped one which meets your requirements.
For H23.5 and H240 owners I can definitely recommend the H26, the increase in living space, the enclosed head and increased weather safety, as being your most cost effective upgrade. Assuming of course, that your vehicle, (I have an Explorer) can handle the increased trailering weight, or trailering your boat is not of prime importance.
