I do not think the replacements will take a stain, but stuff like the "fake wood" I think can be.Can those HDPE replacements be painted/stained/varnished to a nice wood color instead of that anticeptic white?
Home Depot has some trim pieces in red oak that are close to the same width, thickness, and shape of the original teak pieces. Cheap, too: 12-foot sections are only a few bucks. A minor trim on the tablesaw will provide the correct slider gap; and the wood looks great sealed in clear, high gloss polyurethaneI would use oak. It will hold up well under the abrasion of sliding hatches and is of course quite tight grained and hard. Takes varnish well.
VBR,
Pat
I can get Seaboard, another HDPE equivalent to Starboard locally in white or black. It's pricey though. For a 1/2X48X96 sheet it's $220 in white and $240 in black
When you consider maintenance cost of wood, HDPE is a good value in the long run.
Can't seem to find Seaboard or Starboard anywhere locally out here - so I've had to scan eBay and such for sources. There is one company on there that sells 3/4" and 1" stock, though as mentioned earlier it is kinda pricey. They offer it in white, off-white, grey, black....I can get Seaboard, another HDPE equivalent to Starboard locally in white or black. It's pricey though. For a 1/2X48X96 sheet it's $220 in white and $240 in black
Where did you look? We have a place noted for skylights, window well covers etc called Lustercraft that sells it. You may need to expand your searchCan't seem to find Seaboard or Starboard anywhere locally out here - so I've had to scan eBay and such for sources. There is one company on there that sells 3/4" and 1" stock, though as mentioned earlier it is kinda pricey. They offer it in white, off-white, grey, black....
Oh schnit! I didn't think of that! Used the stuff my wife bought for the bathroom cabinet doors. Going downstairs to check the label now...but this is a good point for all to be aware of. Thanks TB!Be sure whatever you use to clearcoat that it is rated for outdoor use. that meens that it has some UV protection and will last al lot longer.
VBR,
Pat
