Have a Hunter-installed Fischer Panda 6 kw generator on my 2009 H41, which starts up and after a while (timing unpredictable) dies when it is being run with both air conditioners. I have had two different mechanics look at it (both FP certified)and have had a replacement control panel furnished by FP installed. No one seems to have solved the problem. Someone (not a mechanic but often quite wise) suggested that the problem could be ventilation (the generator being located in its box in the lazarette). Has anyone else had this problem? Thoughts?
