A couple of weeks ago I posted a question, and got some good responses, about the reef line jam cleats that are located on the boom just under the gooseneck fore & aft. ( http://forums.hunter.sailboatowners.com/showthread.php?t=121952 ) The cleats and the small opening in the boom were preventing the lines to the reefing clews from running freely into and through the boom when raising the sail to shake out a reef.
Attached is a picture of my modification to improve the operation. I've shaken out reefs a few times over the last couple of weeks while out on San Francisco Bay, and the lines run nicely now. The sail can be raised without having to constantly free up the line jams at the gooseneck. Some notes:
- My first attempt to improve was to simply remove the springs from the jam cleat so that the jaw would hang down away from the line. Then after tensioning, the jaw could be manually made to engage and it would hold from the backward pressure on the line. This aspect worked, but the line kept jumping off the very small sheave and wouldn't feed consistantly into the small hole in the boom very well.
- I solved this by adding the fender washer shown in the picture. It's 3/8" x 2". Unfortunately I couldn't find a 2" SS fender washer locally, so I had to settle for the hardware store zinc/nickle plated steel variety. I've coated this standard steel with JB weld epoxy. Maybe that will keep the rust at bay for a while. I first tried a 1.5" fender washer which was available at the local West Marine. But the gap between it an the boom casting was enough that the line would still work itself off the sheave.
- The sheave center pin is not long enough to accomodate both the thickness of the sheave and the newly added washer. So I ground down the thickness of the sheave by about 3/32" so both would fit. Fortunately, still enough room for the line to run freely. (Ed, I did determine that the line diameter that a PO had installed and that I'm still using is 7/16". The Hunter spec is 3/8" which certainly would have been better for feeding into the hole ... but I think still not ideal.)
- Unfortunately, the thickness of the jam cleat jaw was too wide to fit into the gap between the new washer and the boom. So I removed the jaws completely. This isn't a problem since I have led the reefing line down to blocks at the boom base which then can be pulled up and tied off of cleats on the mast.
Although simple in concept, after all the futzing around to get it right, this project took quite a bit longer than originally envisioned ... So what else is new?
rardi
rardi
