Gluten for punishment
51
'88 Macgregor 26D TN River
After months of looking for a 26s I ran accross a 26d. The price was low enough that I figure I would get it and if she needed to be put to rest I could strip the hardware off and at least make what I purchased her for back. So here is what I know about her so far.
I found it on a mountain top in TN. (Im not about to break into song.) Where it sat on its trailer for at least 5 years. Looks like at some piont the hatch was opened and lots of rain water came in. (lots and lots of water and some leaves.) Good news is it appears that there are no leaks below the water line and slightly above it. I got most of the water out and towed it home. I spent the last 2 days drying out the last of the water and pulling out all the parts that where stuffed inside.
Hull seems sound. It at least holds water. I suspect the ballest tank is good too. It was bone dry. I'm gonna fill it up this weekend just to make sure. The uper deck seems to be very solid. I weight 250lb so I was impressed that it didn't even feel a little mushy. I was told the sails where shreeded. The main is shreded. The jib (I think) is on a Mariner Hank On Furler. I appears to be ok. (I would replace it later on) The dagger board and rudder are in good condition, but needs a tiller. All lines need to be replaced and a block or two. It came with a 2-stroke 5hp Suzuki that started right up.(I was amazed didnt expect that). The bimini was in ok condition. The fabric looked brand new except one spot that a mouse chewed through. That shouldnt be to hard to patch. And of course all deck hardware and rubrail needs to be rebedded.
Now comes the part that worries me the most. The bench seats in the cockpit seem to be soft. It also creeks alot when steped on. Those of you that have had this area opened up, what is supporting those seats? Wood? Thick fiberglass? The way the liner is shaped on the inside it looks like there may be a 2x4 run down the middle of that bench. If there is, how much trouble is it to go in a replace that or put something in there to stiffen it up?
I'm still deciding on wether of not to dive head first into this project. Any recommendations/comments are welcome.
Thanks in advance
Jul 18, 2010
51
Thanks for the info MrBill. I drilled a hole to find out whats in there. It has plywood under the sets in the cockpit. Looks like it delaminated. No rot. So looks like shooting epoxy into it will work.
Next question I have is that after removing all the water and dirt from the aft berth, I found that their are thousounds of small blisters in the storage compartment. How serious of a problem is this? My thoughts are to sand this area down enough to remove the gel coat and open the blisters. Then just leave it exposed since you want be able to see this once the covers are back on the storage compartments under the aft berth.
One more question. Is it possible for blisters to form in the bilge? I was just wondering, I dont see any in mine frome what I can see but I was just wondering if that is posible since there is no gel coat or paint in that area. I think thats it for now.
Thanks Guys
cscott
Oct 18, 2007
188
Macgregor 26S - 1993 Aumsville, OR
Spec Sheet
MrBill_FLL, thanks for the spec sheet on the 26D. Do you or anyone else have a Spec Sheet like this for the 26S? I sure would like to get a copy.
Thanks,
Chuck
on the bench seats, I THINK its (thin) solid fiberglass, supported by the inner liner. hard to get to...
not sure about the floor of the cockpit...
http://i64.photobucket.com/albums/h169/ftldiver2/MACGREGOR/m26d_2.jpg
might think about drilling and filling with the thickened epoxy using the calking gun tubes west system sells...
May 4, 2005
4,062
^ On the S diagram they don't show the overhead floatation compartment above the V berth. some of the late (1989?) D models have that. my 88 does not.
cscott
Oct 18, 2007
188
Thanks For 26S Spec Sheet
NORPASM
Steve,
Thanks for the 1991 26S spec sheet. I have a 1993 26S, but the specs are not in my manual.
Again thanks Steve and MrBill_ Fll.
Thanks, Chuck
PS: My 1993 26S has flotation in the overhead above the V-Berth
here you go
Steve
Jul 18, 2010
51
Damage Found
I filled the ballest tank with water over the weekend. There are no leaks to the inside of the boat. But found that what I was hoping was bottom paint flaking off is actually a crack that is very slowly seeping water from the ballest tank. It is a bout 1.5 feet long. It starts right where the stock trailler rear bunk stops and heads aft. Its on the port side.
Also found a ballest tank leak in the back bottom of the daggerboard trunk. Looks like a seam has opened up slightly. Water is not quite a stream but a very fast drip. The daggerboard show no signs of being broken.
So does this make any of you want to run and hide or is this repairable. Im going to check around at some of the local repair shops and get some estimates but first I have to at the very least get some lights on the trailer to keep lawdogs off of me.
