I'm looking into replacing the mounts on my 3QM30F ( 1983 37 cutter ) because I'm getting a lot of noise and vibrations at different RPMs, and I think I may also have issues with the prop, which is a maxi 2 blade folding design.
At 2500 RPM there is a lot of vibration and 'knocking' or 'clacking' that seems to come and go with the waves, ie. as the boat moves down/up, there seems to be an increase in vibration and noise. I've checked the rudder/post and all the bracing down the rudder, its totally solid and strong. I also looked into maintenance on the maxi prop before launch, and it has no adjustments needed or greasing, and it was on soliid.
At 1800 RPM, I do 6 knots, it seems to be the engines sweet spot, but there is still vibration, although not nearly as much as at higher RPMs.
At 700 RPM there is a pronounced banging/knocking sound that comes from somewhere. This also occurs when the rpm is very low. It sounds like the side of the engine is banging against the wood, but I've looked around and not seen that, no clues yet.
Here's the fun part. I asked my local shop for quotes on new mounts, and gave them pictures of the ones I have. They responded that I seem to have the wrong mounts, that I may have JH mounts on my engine!
Do any of you with 3QM30 engines have engine mount pictures, or similar stories? See attached picture of my front mount. I expect you will also think the mounts need changing, but I'm nervous about changing to a 'round' mount as was supposed to be there originally, or replacing with the same ones. I also just noticed how close to metal parts are in this mount. Perhaps thats where the banging comes from....?
