Waypoint - GPS Question
10
C&C 40 Toronto
Could use some assistance with my GPS and waypoint setup.
Say that I have to input the following waypoint - N 43, 16.26 / W 79, 45.62 onto my GPS (Garmin 72)
Because my GPS allows for 3 numbers in the seconds I am wondering what should be input.
Eg, Should 26 seconds be input as 260, 026 or what?
Thanks
Ross
Jun 15, 2004
14,693
Neither. The lat-lon you gave is degrees and minutes and decimals of a minute. .26 minutes is 15.6 seconds.
Apr 22, 2001
497
Hunter 420 Norfolk, VA
Thanks
The reason for allowing a 3 number input in "seconds" is that GPS data is converted to decimal equivalents ... N43, 16. 26 seconds = N43, 16.433 ...
IF the .26 is seconds as you maintain.
http://www.csgnetwork.com/gpscoordconv.html
Feb 17, 2006
5,274
Go to the Setup | Navigation Setup and look at the different ways the lat and long can be viewed/entered. There are usually:
hddd.ddddd°
hddd° mm.mmm'
hddd° mm' ss.s"
In your case you have 45.62 for mm.mmm and 45.260 is acceptable. That 45.26x where x=0~9. But for the most part, you do not have to put anything for the third digit as it is assumed a 0 if no number is entered.
dugout
Nov 15, 2008
40
Pearson P33 Maryland's Famous Eastern Shore
Okay, those are not seconds, those are minutes to 3 decimal places and coordinates are often stated as such. .26 would be .260 for example.
To further complicate this, coordinates are stated in different ways:
Deg/min/sec
Deg/min to 2 or 3 decimals
This is fractional minutes, Min in Decimals
N 43/16.26 is 43 degrees N, 16.26 minutes, not 16 min, 26 seconds.
This would be close enough in DEG/MIN/SEC;
N43/16/16 in DEG/MIN/SEC
W079/45/37 in DEG/MIN/SEC
.26 x 60 = 15.6
.62 x 60 = 37.2
I hope this helps!:)
Nov 6, 2006
10,253
And to further confuse things, you can set most GPS units to work with either degrees minutes and seconds OR degrees and minutes which can be to three decimal places.. so 16.26 could be 16 minutes, 26 seconds or 16 minutes, 15.6 seconds (0.26 X 60 = 15.8) There is a good bit of difference between those two locations !
Ross
Jun 15, 2004
14,693
How did the settlers ever make it here in 1607?
They already knew the way. The entrance to the Chesapeake bay is 37 D north. So you sail southwest from England until Polaris is 53 degrees above the horizon and then sail west. In about a month you hear the lookout shout "land Ho".
Feb 17, 2006
5,274
Well, when Ross was sailing with them in a previous life, they'd have fights over how to read the micrometer dial on the sextant.
Ross
Jun 15, 2004
14,693
We didn't have sextants in those days. we used a backstaff or a cross staff or astrolabe.
Sep 20, 2006
2,955
hddd.ddddd°
hddd° mm.mmm'
hddd° mm' ss.s"
But he was asking how to input 26 sec.
That would be 45' 26" or 45.433'
45.260 is not 45 min. 26 sec.
His 45.62 is 45 min. 37.2 sec.
or am I missing something here.:confused:
Feb 17, 2006
5,274
He was asking about how to input 45.26 minutes and if it had to be 45.260. I was just giving him an option of the different ways to use lat and longs. Some times it is easier to use decimal degrees instead of degrees decimal minutes or degrees minutes seconds. But it depends on what format his chart is giving him. So, use that. At least that is how I interpreted the question.
Ross
Jun 15, 2004
14,693
The clue here is the question needed to be interpreted.
It wasn't clear.
Given that minute of latitude is one nautical mile and a second is about 100 feet, decimals of seconds are from one side of the boat to the other.
