ready to jump in this week and patch some ugly spots on my C34. I have ground them out as little as possible but the gel coat must be "piled up" approximately 1/16" (maybe slightlly more in places) to look right. Question.....I am worried the gel coat will be too thin to fill up to 1/16". Do you thicken gel coat as you do epoxy to keep it from running? Or will the gel coat be thick enough so as to build up to the level necessary? I am ok with the wet sanding and compounding which will follow....just worried about the "build up". Any help very much appreciated.
