Thanks Dan, I'm sure the schematic would help. I sent you a PM with my email address. The Calder book wasn't in stock, it may be one I ordered--sounds like a good resource for my project.
Regards,
JQ
Regards,
JQ
Higgs,I am no expert and am still figuring out how to manage my batteries at anchor.
I have two type 27s, but if I leave the frig on with an anchor light and no shore power they go dead overnight. I used to start with #1 and as it lost power went to #2. I am now using both house batteries at the same time. At anchor ( I have a separate starter battery) I have not yet been able to determine how that works. My thinking is that it is a lot better to run two batteries half way down than each one all the way. One thing I am going to try is turning off the frig overnight figuring it will stay cool enough if not opened. I also bought a solar powered garden light that I am going to use as an anchor light. Have not put this all into play yet.
Recalculating for 1.5 days out and a 50% DOD, I now get a bank size of 200ah--more what I was expecting. (not sure if changing the parameters is cheating or being more in tune with realityThat is too large a battery bank for your size boat. I have a 420 ah bank on a 41' boat but I have solar panels that will put in 100 ah/ day. I would calculate for one days use then come up with a way to recharge. Run engine with standard 55amp alternator (least desireable), one or two solar panels that will put back 20 -30 ah or a wind charger or a combination of the above. I think 210 ah battery bank with solar panel and occasional engine charging would do.
I liked their info on ditching the 1-2-both battery switch and wiring the alternator directly to charge the house battery, and then a parallel switch for combining cranking amps if needed for starting emergencies.It's not the size of your boat with the equalization feature on a charger or not, it's you blinkin' wallet. Wanna spend more on batteries or keep the ones you just bought. No brainer answer, get the equalization feature. I did send you to www.amplepower.com, tech tab download the Ample Power Primer, didn't I? If I didn't now I just did.
Don't bother, keep the 1-2-B switch. Combining banks should never be needed, you shouldn't have emergencies.I liked their info on ditching the 1-2-both battery switch and wiring the alternator directly to charge the house battery, and then a parallel switch for combining cranking amps if needed for starting emergencies.
I'm giving this some thought.
JQ, thanks for coming back on this. Maine Sail and I have been promoting that simple design for years, and we've helped many skippers out, offline, with their designs. We know you'll appreciate the simplicity. All the best, StuHi Stu,
Just finished reading your links on 1-2-b switches and keeping #2 bat bank as a reserve only. It keeps things simple, makes a ton of sense too. I'll definitely be going that route when I start my upgrades.
Thanks again,
JQ
