'89 ODay 24 LE The front stanchions are leaking. Are there any special stanchion gaskets to stop water leaking into cabin...or will caulk or any type of gasket work. Not sure what's underneath before we take it off.
The bases should be through bolted and you should be able to access them inside. If they have been leaking then you may have problems with water intrusion into the deck core. This is the right forum for problems related to leaking deck fittings. Good luck.
