Here is a pic of the completed rudder. FINALLY Looks pretty good now. Also a pic of the special tool I made to get the expanded foam out of the holes I cut to pour it in. I wanted to be able to put the plugs back in solid and have them flush. So, here is the tool I made. Be sure to notice the exacting cut of the abrasive surface, made using the latest in hi tech blue handled scissors. Also the abrasive surface was attached to the exclusive zinc plated stem using super glue from my first aid kit. It was relatively expensive. Fortunately the abrasive surface was cut from a worn out sanding disc, saving a few bucks. The super glue was in a 4 for a couple of bucks pack, and of course the big ticket item was the stem. Which cost upwards of 50 cents.
