Does anyone else have a problem with the starboard genoa sheet configuration that I seem to experience? When I run the sheet from the block on the track to the winch, it crosses over the middle of the cleat and makes tying down the line difficult. I can get the sheet on the one side of the cleat easily but I need to push it under line crossing over the cleat to get it in the other side of cleat. This is not a problem on the portside as the line does not cross over the cleat.
This is not a major problem but in a heavier wind it may be and it just doesn't seem to be designed correctly, but then again, I may be doing something wrong.
