Gear ratio 2.21 or 2.62
2,366
My friend is repowering his Maxi-95 with Yanmar 3YM30 + KM2P gearbox. Question is, should he go for gear ratio 2.21 or 2.62? What's the benefits of one over the other? Appreciate advise. Thanks.
Ross
Jun 15, 2004
14,693
For these low speed boats the larger prop turning at a lower speed will be more efficient. If he has room for the prop the the lower ratio is indicated.
Dec 2, 2003
1,637
Measure the perpendicular distance between propshaft centre line and the hull.
Deduct 15% and this will give the radius of the largest prop which will fit without causing too much turbulence & vibration from interference between prop tips and hull. i.e. prop walk.
Then do the calculation for the engine/boat/prop combination using the prop calculator on Castle Marine's web site for each gearbox ratio:- http://www.castlemarine.co.uk/pitch.htm.
This should give the basic data for pitch, boat speed and efficiency etc.
If a suitable prop is found for the higher ratio (i.e. 2.62) it should give best propulsion.
BUT a big prop causes much more drag when sailing so this route should only be followed if it is intended to fit a feathering (or folding) prop.
If you are concerned with sailing performance without fitting a featherer or folder then a smaller prop with two narrow blades is required and the 2.21 gearbox will give this - although you will almost certainly be disappointed with both sailing and motoring performance.
Oct 29, 2005
2,366
Ross, by lower ratio I gathers you meant 2.62 since he'll need a larger diameter prop with this ratio.
Donalex, he intend to fit a Max prop (feathering). Thanks for the link to Castle Marine Propclac. Very informative.
Ross
Jun 15, 2004
14,693
That is correct. 3:1 is a higher ratio than 4:1. Just as 1:40,000 chart has larger detail than 1:80,000.
Oct 29, 2005
2,366
Ross, thanks for the confirmation. Its clearer now. My friend wants a 2.21 for speed but his dealer and I recommends 2.62. He thought he could go fast!! like >hull speed with bigger horsepower. ;)
Ross
Jun 15, 2004
14,693
He needs to look at the graphs of speed and horsepower for displacement hulls. It doesn't take much power to motor a 30 foot boat up to about 2/3 hull speed but after that the curve starts to get very steep.
