Hello All,
I have attached pictures of my mast on my 272LE 1988.
I was doing an exam of my boat and noticed 2 problems at the mast.
1. These screws at the base of the mast are loose. They seem to back right out of the holes with no grip.
What are they doing as the length of the screw seems very short????
I will not be sailing soon so I can wait till I get answers on how to fix. I didn't try to just retighten although that seems the simplest. Something just seemed weird so thought I'd ask first.
2. The coating for the white wire is obviously cracked and broken and needs replacement. It looks like a 2 inch piece of coaxial cable. It is probably for the antenna for VHF but haven't confirmed yet. The VHF works well and was tested but I cant let this remain like this. Is this a major PITA to repair????
PS the main sheet is sticking at the sheave on the starboard side. Any suggestions on how to prevent/cure sticking. Not fun when dropping sail in high winds and sail wont come down and has to be wrestled on wet pitching deck.....you get the picture.
