Got the shaft log repaired, the shaft seal back in place, engine aligned,motor mount bolts changed out and everything bolted down and done. So I spent three hours this morning removing the backing plate for the pedestal. Was certainly just in time, and probably way too long in being done, but out of sight out of mind. In fact is someone on this board hadn't said something, I might not have looked at is as hard as I did. No way that puppy would have lasted another year. So, now I am once again shopping for parts. Unfortunately the way it's made, a simple plate under there won't work. The sheaves are mounted in such a way as to make home made not an option. So I am still crawling around down in the bowels of a boat, and listening to the radio and getting more and more frustrated with the oil spill. The world and work goes on. Pics attached.
