I used my fresh water pump today and when finished, tuned off the switch at the panel. Went to use it an hour later and the pump did not come on / pressurize. I checked the back of the DC panel and the wiring was snug...did not check the voltage at the pump itself.
The pump is original to the boat (18 years old)...do these just quit that suddenly or do they usually give indications before pooping out? This one just seemed to die. Anything else I should check on before replacing?
