Marine Air reset or fuse?
Persy
Dec 22, 2004
192
Hunter 42 Madisonville
I have a Marine Air a/c system on my boat. 1 unit forward, 1 aft, both have their own passport panel, but share 1 raw water intake.
When the seawater strainer clogs with grass, usually the panels read HHH letting me know the unit has overheated. I unclog the seawater strainer and start right back up.
The strainer clogged tonight while I was sleeping. Both panels are now unlit and neither will start up. the generator is working fine and shows 120 volts to their side of the panel.
I am in the Abaco Islands on a cruise and am sure I will have problems finding help.
Does anyone know if there is some sort of reset button or fuse on the units I need to check...or other ideas?
any ideas very much appreciated!
thanks,
Guy
Persy
Dec 22, 2004
192
mine has reset button on the electrical box on the unit......
good luck
can't find it on mine...
Is yours a Marine Air Vector Compact?
Do you remember where on the unit the button was?
thanks
