OK, so I finally got this fire extinguisher to stop leaking fuel all over the place. There is no emergency way to shut this off or release the pressure so I need to add a ball valve to the nozzle.
The problem I am having now is when I turn the valves to the on position, alcohol starts leaking at the connection point of the burner and the injection nozzle. I disconnected the burner and I see where the alcohol is coming out in a perfect little stream out of the injection nozzle.
Anyway in the first pic the burner is almost connected in the second pic it is all the way connected. When I try to use the stove it leaks at this connection point.
Is there supposed to be an O-ring in there where the burner meets and connects to the injection nozzle?
