Plywood panel on cuddy floor (1984 DSII)
Hi,
I'm the new owner of a 1984 "25th Anniversary Edition" Daysailer. (I believe that makes it a DSII...?) It's been sitting on a trailer in someone's yard for the past four years.
Looking into the bilge through inspection ports on either side of the centerboard, I noticed it was a little wet. The ports looked to be pretty sun-baked and the threads were completely dry, so I assumed rainwater water was coming in that way.
However, after a pretty significant rain yesterday, I noticed the open cuddy had nearly no water in it. I know it rained in, and I would have expected the water to be up to the level of the drains to the cockpit. Instead, there was just a tiny little bit of water sitting in the corner where the centerboard trunk meets the cuddy threshold. I wiped it away with my hand and it ran over to the plywood panel and disappeared down into the bilge. Hmmm - so I think that might be how the water is getting in. The previous owner thoroughly washed it prior to sale, and I'll bet he ran plenty of water into the cuddy.
I have a few questions...
Is that plywood panel original? It's on the floor of the cuddy under the centerboard rigging, about 8"x16" and runs between the fore end of the centerboard trunk and the mast plate . It's 3/4" plywood with some sort of dark-brown laminate on top. The things that make me suspect it isn't original are that there are some visible voids in the plys, i.e. it's not marine-grade plywood, it isn't cut perfectly cleanly.
I think I should caulk it to prevent the leakage into the bilge I described, but how to remove it? It appears to be glued down - there are no visible fasteners. Could there be some fasteners hidden under the laminate? Or does this panel slide out somehow? Or do I need to carefully work it loose with a putty knife... or even just leave it in place and caulk around the edges? Honestly I'd prefer replacing it. If it isn't original, I wonder if a prior owner cut an access hole to repair the centerboard or mast step for some reason?
Any insight/advice/speculation is appreciated.
Also, if anyone knows what sort of plug I could use to plug the transom bilge drain, that'd be much appreciated as well! The thru-fitting is a white plastic two-screw flange, no threads, ~17mm (11/16") ID. I see a similar plug assembly - except it's black - on the DR Marine site, and I was thinking there might be a chance the plug will fit, or, failing that, I could just replace the entire thru-fitting.
Thanks again!!
- Doug
Hi,
Thanks again!!
- Doug
