I have a Freedom 20 charger with the remote and 2 200 ah 4d AGM batteries. Last summer I purchased another 200 sh 4d while on a cruise because of a mis-diagnosis of a problem. Now I have three 4d's which the boat yard mechanic has tested and tells me "..they all test the same." Putting aside for a minute what that actually means, I am trying to decide how to best use them. One notion is to combine the older 2 batteries into one 400ah bank and use the third as an engine battery. Or I could combine all three into one 600ah bank and buy a starting battery. Which I think is a better idea but I haven't run that on Bill Roosa's spreadsheet yet. In any event, should I put the house bank on either the A or B switch of the battery selector or use the echo charge feature of the Freedom 20?
Of course, savy battery-philes on this forum will know that if I use the A/B selector, I should manually adjust the remote control for the size of the battery bank when using either the A or B. That does not appear to be necessary with the echo charger - for what reason evades me.
If I use a 600ah bank I could probaby charge it only at the dock with the Freedom and direct the alternator output (35 amps at best) to the starting battery.
Although the batteries test "..the same.." I am leary of putting the old with the new. I never did that last season but, of course, I found the boat with the selector on "both" after the test.
Advice? Comments?
Advice? Comments?
