Sailing this weekend, BTW it was great in the upper Chessy!! appears to have reviled some minor play in my rudder post. On Saturday is was blowing 20 NW and went W. this caused some confused water in the channel. The bow was pounding more than usual, as a result I felt a slight thump in the wheel. Went below to see if the post was moving and indeed it was. Later on the hook I went overboard to check it out, and there is some play forward-aft in the post bearing, but not a lot. Question, how do you tighten this up?
