Can I get some advice about designing a reefing system for my Catalina 22 Sport? The P.O. does not seem to have had any sail controls on the boat except for the most basic – not even a Cunningham. I knew this when I bought her, and so I get a blank slate, no hardware to remove or holes to fill. I would like some help on what will work well.
The more that I study reefing, it appears that single line systems don’t offer the best sail shape. My current factory stock main has a single reef point that is bit shallow. I am not sure a poorly shaped reefed sail with a shallow reef is much better than a well shaped full height sail. I want a reefing system that gives a good sail shape. Also, if I order a new main in the future, it will probably have two reefing points, so the system that I install would ideally adapt to this as well.
My current starting plan is to add a Cunningham, perhaps with a hook so that it can be moved up to the reef tack. I might add two Cunninghams so that the second is always ready. I also need a better outhaul (unreefed), probably 4:1, perhaps a cascaded system such as shown on Harken’s website.
If I understand correctly, the outhaul is not good for taking leech tension generated by the vang or mainsheet, hence, I will need some way to take the vertical forces, maybe by tying down the reef clew to the boom. Could I tie a line in the reef clew and tie that down around the boom? (I think that this is called an earing?) If I did that, could I put the outhaul on a shackle and move it to the new clew?
It is a small boat, I don’t want overkill in hardware, but I want a good reefed sail shape. Am I on the right track here, way off, or where do the ideas above need correction or improvement?
Thanks,
OC
Thanks,
OC
