OK..me again, the original poster. Thank-you for your comments. I do want to add a thought or two. First, a solenoid-type 24VAC zone valve will open with 12V DC...so no need for difficult re-working of the electrical system.
They may do so but won't do it for very long and are designed for 24VAC. I used to represent one of the largest control makers in the hydronics industry. We invented the multiple circulator relay and the multiple zone valve control. I would not advise trying to run a ZV designed for 24V on 12V. The real issue is that a product like a Taco Gold Head draws .9A at 24 volts. Taco's have a manual lever but if you are bending over to open it then why not just open the seacock?
Of course, they are not 100% reliable, but even a leaky zone valve in combination with a failed hose clamp is a lot better than simply a failed hose clamp.
I don't understand how you come to that determination as there is no telling how far open or closed the valve will fail in. It may fail just barely cracked open but it may also fail totally open.
A bilge pump could probably keep the boat afloat. Also, if used for a few minutes while on the head or for longer periods, but only while the motor is running, the power consumption shouldn't be a big factor.
.9 amps is still quite a bit of power consumption. When we are on the boat every seacock except for the head remains open. When we leave they are all closed. For us that would be four valves needing .9 amps each to remain open.
Finally, most are made of brass and all are normally (power-off) closed with manual opening levers.
Honeywell and Taco are power off closed, Automag the third most popular is power closed. If you need to bend over to use a manual lever on a ZV simply close or open the seacock handle.
Brass, specifically yellow brass, what most home center ball valves are made of, should not be used in below water applications. Yellow brass has a zinc content of roughly 40% and the valve body or vlave stems can be dezincified and destroyed in rather short order. Seacocks are generally always made of 85-5-5-5 bronze. Mismatching yellow brass and 85-5-5-5 bronze can be very dangerous. This is a valve from a home center that was less than a year old and the ball was totally missing as in NOT THERE. You could turn the handle and nothing happened.
If my memory serves me correctly the Taco body is silicon bronze but the valve stems and internal parts are yellow brass. The Honeywell's are brass and draw .3A @ 24V because they are not heat motor type. There are others too like Sparco, B&G & even White Rogers but they are small players in the whole scheme of the ZV market.
That said, like most sailors, I am a K.I.S.S. guy (even though we all chose to sail, rather than just go for a nice walk on our day off). I'll keep the zone valves off my boat for now.
Thanks
In reality there is nothing KISS about a sailboat..
I do agree that ZV's on a sailboat would be best left onshore to fail on hydronic heating systems..
The cheapest insurance is to manually close them, inspect and replace hoses when needed and use double non-perforated high quality hose clamps such as AWAB's...
