Oil filter gasket failure
3,502
- Telstar 28 Buzzards Bay
I think Maine Sail meant gaskets... not filters... fitting two filters on the engine would be a really neat trick. :D
Looking at the picture it seems the OD of the filter is bigger than the on engine filter adapter. If this is the case the gasket could easily blow out. I don't recall ever seeing a filter with a diameter bigger than the filter adapter. Another potential issue that I don't recall seeing mentioned is that when the filter was changed the old gasket stuck to the surface and you then had two filters on there..
Oct 22, 2008
3,502
Jeeze, quicker than I can add photos and edit...:doh:;)
LOL... sorry about that... :D
BTW, does painting the hoses hurt the rubber they're made of??? I'd imagine it doesn't but some say you shouldn't paint them. :D
11,760
I don't know but it is a HUGE peeve of mine when you spend 10k on an engine and they slap paint on it like it's a Waste Management dumpster... For 10 K I would expect them to at least use some masking tape:doh:
Oct 22, 2008
3,502
LOL...that is very true... and some of the engine paint jobs I've seen on new engines are far worse than what I've seen on dumpsters...
