Personal Property
Tangible personal property is taxable where it has established "permanent situs" (location), regardless of where the owner lives. The only exception is personal property belonging to members of the armed services. Some types of personal property do not have a fixed location and are movable; as a result, determining permanent situs depends on a number of factors including the type of property, the way the property is typically used, and where the property owner lives.
Aircraft and Vessels
Private aircraft are taxed at the location of the airport or hangar where they are usually kept. Commercial certificated aircraft are taxed on an apportioned basis in each county to which flights are made. Vessels are generally assessed where they are habitually located. A small boat not habitually kept at a mooring, but lifted from the water and trailered to the owner's residence or other location, is taxed at the location where it is usually kept.
