I should be the one least surprised, right?
I ran the heating system all day today while working on the bottom and other projects.
Started with gravity circulation to the bulkhead tank. The top portion was noticeably warmer than the bottom within 15 minutes of getting the Newport started. The gravity feed hot water to the head was comfortably warm in an hour, normal washing temperature in two, and almost too hot in three.
I then switched over to the circulating pumped loop to the main hot water tank. Four hours got the pressurized hot water to what felt like about half the temperature you would want for a shower but it's definitely working. The estimate of 8-10 hours at the outset for heating up the main hot water tank looks like it will be pretty close. I could have taken a shower at the temperature it reached but it would have been barely tolerable running full hot.
A pleasant surprise was still being able to get hot water in the head with the main tank circulation loop going. The flue throws off enough heat that is soaked up by the bulkhead tank that the temperature didn't seem to go down a bit.
There was some boiling and burping with the circulating loop running but some tweaking of the flow rate should minimize that. The gravity loop to the bulkhead is absolutely quiet as the thermally driven circulation is self regulating.
The only thing that didn't warm up as much as I expected was the head. The aluminum panel behind the stove doesn't get very hot, at least with the boat's skylights wide open to dissipate the heat. I needed the hole and the removable screen for piping access anyway. When the heater has been running for a couple days, I think it will still take the chill off the head.
Details here if you are new to this topic.
http://www.rogerlongboats.com/10Winter.htm
