I finally fired up the Dickenson Newport heater. There definitely is a learning curve to starting them up and one point on that curve is having the glass window soot over so that it obscures the fire as well as a cast iron stove door would. After that, whatever is going on inside is sort of a mystery but it did get warm. I was able to confirm that the flames were above the burner ring before the view was obscured.
I ran it for about an hour and am a bit concerned not to be able to see any evidence of the water coil getting the least bit warm. The flue is too hot to touch more than a lick so there is plenty of heat but, with the circulating pump running, the copper pipe between the stove and the PEX tubing loop to the hot water heater didn’t even lose its chill. I could hear water running through the tubing at the circulating pump aft and tried throttling it down to minimum flow but no change.
It’s only a short trial and I’m still at the stage where I could have air in the system so I won’t lie awake all night. The hot water part of this was half the cost of the whole system so I sure hope it works.
http://www.rogerlongboats.com/10Winter.htm
Until the window soots up, the flames sure are pretty.
