Best lubricant for plastic zippers
82
Catalina C320 mk 2 Australia
What is the best lubricant to keep plastic zippers working on canopies? What is the best sealant for canvas? Cheers.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
McLube SailKote for zippers
303 High Tech Fabric Guard for Sunbrella or other synthetic canvas.
Beneteau 323 Annapolis MD
On page 157 of the Sailrite catalog there are two types of zipper lubes. I've heard that Chap-Stick works also.
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
A bar of soap or bee's wax is an easy way to go. It doesnt last as long as mclube but its not petroleum based either so no dirt build up.
Oct 22, 2008
3,502
The McLube SailKote is designed not to pick up dirt. It is a completely dry lubricant, and I wouldn't have recommended it if it wasn't.
7,745
Alden 50 Sarasota, Florida
By far, the best lubricant/protectorant for zippers on any boat is Zip Tech. Although other products folks have already mentioned will suffice, my experience is that none will outlast or protect better than this stuff.
My canvas guy turned me on to it a number of years ago and now everyone on my dock borrows mine every spring which is always good for a few beers.
http://www.mcnett.com/Zip-Tech-Semi-Solid-Zipper-Lubricant-P199.aspx
zeehag
Mar 26, 2009
3,198
the canvas company i respect most used dry teflon spray..is perfect. no build up . no muss. no fuss. all perfect function.
brand name is irrelevant, as long as it is dry teflon.
JerryA
Oct 17, 2004
550
Hunter Hunter 170 Sandusky Bay, Lake Erie
Lots of people recommend soap and bee's wax as a lubricant. In my lifetime I've tried several times with unacceptable results. Each time I tell my self "oh it will probably work here", and every time I've been disappointed. And then I have a mess to clean up before I can lubricate with something else, because contrary to popular belief, soap and bee's wax do collect dirt. The first time, and every time, I used Sailkote I have been amazed at how well it works and why it isn't better known. I've loaned it to my friends that aren't sailors, and every time they come back wanting to know where to buy some. So, soap and bee's wax might have been grandma's answer to squeaks, and I'd still force myself to use it in a pinch, but not if I'm anywhere close to a can of Sailkote. Sorry Rick, I just had to get up on my :soapbox:.
JerryA
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
I am really confused here. SD recommend SailKote and Don represents Zip Tech.
Personally I have used 303, not the kind for sunbrella, the other kind. So which one is better the Sailkote or the Zip Tech. I would hate to make a mistake here and get the wrong stuff. My zippers are starting to show there age and are close to needing replacemen. Amazing how the sun makes them disintegrate.
7,745
Dave
I don't think you can go wrong with either and I doubt there is any evidence showing which is superior. Neither is a magic bullet and if your zippers and thread are deteriorated now, neither will bring them back but either may prolong their life. Sailkote is a spray; ZipTech is a stick which I have found facilitates application if that matters to you.
srokos
Mar 14, 2010
8
Hunter 1981 Hunter 27 Willsboro Bay Marina
Spray goes allover soup is mess. The best way to lubricate zippers I know is petroleum jelly. Take small screwdriver and pres the jelly in the slider and slide back and forth about
one foot then repeat- deepens on lengths of the zipper. Works like a charm on plastic and
metal.No mess and cheep!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Good luck Steve
zeehag
Mar 26, 2009
3,198
a manufacturer of dodgers and biminis and such in lost angels says to use nothing but spray on dry teflon...goooodluck--i donot know brand name----lol
have fun with the results if not used--i have used it for many many years with awesome results. EVERYTHING else makes the fabric yukky and gums up the zipper. but is your choice. have fun.
larryw
Jun 9, 2004
395
Beneteau OC400 Long Beach, CA
what many people are unaware of that plastic zippers have a built-in lubricant. Just zip it back/forth or up/down a few times a month. the plasticizer in the plastic will come to the surface.
Feb 17, 2006
5,274
This is a timely thread. I have a stuck plastic zipper in my cabin. I want to fix it but am afraid that I will break it and well, that would be that. Will the spray-on dry Teflon work to loosen the zipper? I have tried working it loose but still have concerns that it will still break.
Jan 10, 2009
590
PDQ 32 Deale, MD
Breaking it loose and lubricating it are 2 very differnt things.
If it is an aluminum slider (most are) then corrosion is the problem. Either a mild acid (vinagar, many weak acid cleaners, or even coke) or PB Blaster (spray penatrant - there are others, but this one has many fans and is exceptional on aluminum). I have used both aproaches on wet suit zippers.
Then Sailcote or other dry lube.
Oct 22, 2008
3,502
The reason I don't bother with ZipTech, even though it is probably a bit better than SailCote is simple, I have SailCote on the boat already, and there's no point in buying ZipTech if it isn't going to be an order of magnitude better than the results I get with SailCote.
Actually the SailCote I have is a liquid, not a spray. It is far more economical to buy Sailcote by the bottle. If you find you need to spray it, buy yourself a oil mister can with the built-in air pump at the local kitchen/home goods store...fill it with SailCote, pump it up and spray away. I apply Sailcote by putting some on a rag and then running the rag up and down the zipper a few times.
Oct 22, 2008
3,502
but it collects dirt and gums up the zippers after a time in a lot of cases. Also, petroleum jelly can attack certain rubber compounds, like the latex often found on drysuit seals and such... so, is not ideal for use where it may come into contact with such materials.
Good luck Steve
Someone recently posted on this board that his experience was that the newer West Marine fabric conditioner is a superior Sunbrella treatment than the infamous 303 for keeping water off his dodger and bimini.
Like sailcote or Zip Tech, there are choices out there, and choices for you to make...
Feb 17, 2006
5,274
Thanks, I'll give the PB Blaster a try. I have vinegar on the boat. It has proven to be a very good solvent, but the lingering smell sometimes is not worth it.
caguy
Sep 22, 2006
4,004
I use the same Silicone spray that I use for my sail slugs. It dries quickly and doesn't stain.
