I Have an Evinrude 6hp 2 stroke out board that has since I've owned it (4yrs) been really unreliable on starting. It now seems to be getting worse, sometimes it will start 1st or second pull. On other occasions I have to pull countless number of times. The Engine is quite old about 20 years, but I only use this to get out of the creek to race the boat so dont want to spend a lot of lolly on a new one, added to which I dont take kindly to being beaten by anything mechanical
I have cleaned out the carb (twice) Changed the plugs and checked the gaps, the spark seems substantial.
I am sure it is a fuel stavation and have checked the fuel pump delivery. If I disconnect the fuel pipe from the carb and turn the engine over only a small amount of fuel drips out, compared with when I squeeze the rubber ball. However once the engine starts it runs like a bird and there is no evidence of fuel stavation. I have checked the obvious.There is a lot of talk here about ethanol but the fuel is fresh. Any suggestions please? Epsilonblue.
